Old 10-04-2004, 02:12 PM   #1
tmar89 is on a distinguished road
Lilliput flickering
Does anyone else have the problem with their Lilliput where it flickers on and off as if it was Auto-Tuning all the time? I don't get it. It happens randomly and it has nothing to do with the connector because I cut the DIN and soldered the wires together to ensure a solid connection and it had no effect. I hate this screen!
tmar89 is offline   Reply With Quote
Old 10-05-2004, 10:37 AM   #2
markgm is on a distinguished road
Mine would do it when I had the refresh rate over 75. Maybe look into that.
markgm is offline   Reply With Quote
Old 10-05-2004, 10:40 AM   #3
I have mine set to 85Hz.. interesting idea. What do you set it to? When I set it lower, the screen has a "roll" in it similar to when you see a computer monitor during a TV show.
Old 10-06-2004, 05:30 AM   #4
st3w4rt is on a distinguished road
This might be a long shot... Mine is installed into the dash where the heater vents used to be. When the heat is directed to the windscreen it also vents to the rear of my screen. after a short period I start to get flickering. If I turn the heating system to cool or put on the air-con, everything returns to normal i.e. no flickering effect.
Hot circuits = flickering
Cool circuits = normal
st3w4rt is offline   Reply With Quote
Old 10-06-2004, 10:59 AM   #5
I set mine to 75, and it went away. What is weird is usually you do the opposite to get rid of flicker...set it as high as the card can go. I'm going on 2 or 3 weeks now with no flicker. I never minded during the day, but at night it would drive me nuts.
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 10-26-2009 05:33 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput flickering issues SubPuter LCD/Display 5 01-28-2004 10:53 AM
