Old 10-04-2004, 08:51 PM   #1
ukchris's Avatar
ukchris is on a distinguished road
Extending Laptop Screen Cables
I have an old laptop and I'd like to mount the screen on the back of it to make it sort of kiosk like. Any tips on finding a cable that would fit? I've attached a fairly poor picture of it, what are the chances? I figure I could extenmd the power one without too much trouble but I'm not sure I want to mess with the video.
It's a Compaq Presario laptop BTW.
Chris.
ukchris is offline   Reply With Quote
Old 10-04-2004, 08:57 PM   #2
ea972271 is on a distinguished road
Someone on here claims to have done it, I think the trick is to keep the inverter as close to the screen as possible, or you will not get good brightness at all. I believe i read all about it on this forum somewhere.
Hope it works out.
ea972271 is offline   Reply With Quote
Old 10-04-2004, 09:06 PM   #3
Check this out:
http://www.mp3car.com/vbulletin/show...7&page=1&pp=15
Old 10-05-2004, 01:52 PM   #4
ukchris's Avatar
At the moment I'm gutting the laptop, as the screen cables are not long enough to reach if I put the screen on backwards I thought I might reassemble the boards on the back of the screen instead. It's amazing how many bits there are in these laptops once you go at it with a screwdriver and torq set.
Old 10-05-2004, 04:17 PM   #5
Yuriy's Avatar
Yuriy is on a distinguished road
Here's a little FAQ on laptop LCD that I wrote a while ago
http://www.mp3car.com/vbulletin/lcd-display/28196-extending-your-laptops-lcd-cable-faq.html
PS: my early version of my very first setup (the one that's voted most ghetto ) had the gutted laptop sit right behind the screen, in the dash. You could probably do that if you aren't concerned about your casing and things like floppie drives. Although I do recommend to keep the casing as it is to avoid shots circuits and to keep the stock laptop battery inside for your standby needs.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 10-05-2004, 04:54 PM   #6
ukchris's Avatar
I'm not sure I can extend it with the wires and keep the inverter close, there are two wires from the screen to the inverter daughter board, I assume video and power. The daughter board then mounts onto a connector on the MB, no cable involved. As such it is looking as though I need to keep the daugherboard and motherboard real close.
Chris.
Old 10-05-2004, 08:12 PM   #7
Yuriy's Avatar
Chris.
Oh, I was afraid this would happen. You might be able to use a separate inverter though. Theoretically you should be able to use an inverter extracted from a battery-powered blacklight or any other battery powered device that uses neon tubes.
Old 10-05-2004, 08:28 PM   #8
ukchris's Avatar
I just took the screen apart and it looks like the inverter is actually separate and could be extended quite easily, that doesn't help me much though as the video cable is still only about an inch long and is a sort of fabric ribbon cable so I still have the distance issues with the daughterboard.
Chris.
Old 10-06-2004, 03:33 PM   #9
Yuriy's Avatar
Try www.molex.com they might sell you a custom connector that you will be able to extend.
Cheap working 9.6"Monochrome 640x480 VGA LCD screen & ISA controller card with cables Frank Grayson General Hardware Discussion 14 12-09-2005 04:03 PM
laptop screen ibangdchoeclips LCD/Display 1 06-12-2003 02:19 AM
laptop screen model number mp3z24 LCD/Display 6 05-27-2002 10:00 AM
can you use a laptop screen for a mp3car setup? brandondere General Hardware Discussion 8 03-21-2001 10:41 AM
What kinds and numbers of cables is the screen mounted with darkwingduck General Hardware Discussion 0 01-06-2000 07:56 PM
