Old 10-05-2004, 10:38 PM   #1
lookinco is on a distinguished road
VIDEO groud loop isolator
My headunit is a Pionner AV system with a 7" LCD. I believe I am having a ground loop with my headunit. I have a total of 8 LCDs in my car, none of them have video static except for the one with the headunit. The static is there whether I switch from computer, VCR, or PS2. The static is gone when I have the engine turned off.
None of the other LCDs have static, so I believe it's not the source causing the problem.
After research, I believe I am having a ground loop between my headunit and other AV equipments.
Will grounding my headunit and other AV equipment together with the same ground solve the problem? Only problem is my headunit is grounded in the front of the car while everything else is grounded in the trunk. If I have to ground it together, then I would have to run a long 6ft wire from the front of the car to the back.
Someone also suggested about cutting the shield on the video cable so that it is not grounded with my headunit. Will that work? How can I put the shield?
Lastly, have anyone tried any Video Ground Loop Isolator? Where can I find them?
HELP HELP HELP
Honda Lagreat Carputer Project. Mobile Entertainment
http://www.mp3car.com/vbulletin/show-off-your-project/33936-honda-lagreat-carputer-project-lots-pics.html
Full Spec for mods check out:
http://www.hondashowoff.com/profile.php?id=3766
lookinco is offline   Reply With Quote
Old 10-05-2004, 10:49 PM   #2
ppgt94's Avatar
ppgt94
Interesting question about a video ground loop isolator. If the signal is composite with a phono plug (RCA) I wonder if you could just use one channel of a "audio" GLI.
ppgt94 is offline   Reply With Quote
Old 10-05-2004, 10:50 PM   #3
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
man i had the same problem as you with my old civic when i hooked up my xbox. i took to to stero shop. where my friend works and he told me mostly it happening from the computer chip in the. i think its called ecs or something. anyways, just seperate the video cable from the power behind the tv. that should do the trick.
kickercivic1 is offline   Reply With Quote
Old 10-05-2004, 10:56 PM   #4
BiohazrD's Avatar
BiohazrD is on a distinguished road
Yeah, I was going to say to make sure the A/V cables don't run alongside any power cables.
Quick! To the Popemobile!
BiohazrD is offline   Reply With Quote
Old 10-05-2004, 11:00 PM   #5
Raw Wave
http://www.allenavionics.com/VHumElim/RCA.htm
Old 10-05-2004, 11:04 PM   #6
Raw Wave
http://www.elect-spec.com/video.htm
look at quater of a page down its $60
Old 10-06-2004, 12:26 AM   #7
I tried to use one channel from the ground loop isloator bought from radio shack and it didn't work as I expected since video and sound run at a different frequency. I do not think it is the video picking up noise from power cable as I tried running different cable at different location with same results.
One thing I tried today was touching one end of a wire that's connected to ground to the RCA input terminal and it made most of the video hum go away.
Maybe I will have to pick up one of those video ground loop isolator but they are expensive.
http://www.mp3car.com/vbulletin/showthread.php?t=33936
Old 10-07-2004, 06:55 AM   #8
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Try the screen with the car off. My car creates a massive amount of interferance with my LCD when it is on.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-07-2004, 07:17 AM   #9
The interferance on my LCD is there ONLY when the engine is on. When the engine is off there's no interferance at all.
Media Car video player MatrixPC MediaCar 2 03-22-2004 01:33 PM
Suggestions for a Video Ground Loop Isolator... Gutter LCD/Display 6 02-06-2003 02:31 PM
FS: Radio Shack Ground Loop Isolator! mwinkler Classified Archive 0 04-11-2001 11:38 PM
ground loop isolator help digital chaos General Hardware Discussion 10 03-11-2001 02:38 AM
Where does ground loop isolator install? grandamp3 General Hardware Discussion 6 09-14-2000 09:10 AM
