cjastram,
I think this patch is included in 2.6.7 kernels and higher. I know it is in the 2.6.8.1 kernel because I have the module compiled and loaded on my system. It's located in the Device Drivers, USB support section and is called "eGalax TouchKit USB Touchscreen Driver".
You also have to have the "Event Interface" loaded as a module or compiled into the kernel as the touch screen driver uses this interface to create a device to report position and button clicks to applications that use touchscreen input (in my case xfree86).
Then, in XF86Config file you need to create an input device for the touchscreen interface. my device definition looks like this,
Section "InputDevice"
Identifier "touchscreen0"
Driver "evtouch"
Option "Device" "/dev/input/event**insert yourdevice number here**"
Option "DeviceName" "touchscreen"
Option "MinX" "1950"
Option "MinY" "100"
Option "MaxX" "110"
Option "MaxY" "1830"
Option "DragTimer" "200"
Option "MoveLimit" "600"
Option "ReportingMode" "Raw"
EndSection
I don't remember what all the options do exactly I but can tell you that I had to calibrate my touchscreen by trial and error. Basically change min/max X/Y values save and restart X until you are happy. There may be a better way of doing this, but I haven't found it. Also, don't forget to include the line
InputDevice "touchscreen0" "SendCoreEvents"
in the "ServerLayout" section of the XF86Config file. I'm not sure if you need the "SendCoreEvents" option in there though.
I know there are a couple of sites that describe in detail how to set things up. I just never bothered to save them so if you run across them can you post the urls to this thread?
good luck
-momanz
