Old 10-07-2004, 10:07 PM   #1
Has trouble reading.
sanbas's Avatar
sanbas is on a distinguished road
Best monitor for Double Din?
I am trying to figure out which monitor would be the best fit on my dash. If the LCD is too big for my double din then i dont mind taking the casing out and somehow using the LCD only for mounting if possible.
Options so far include:
Lilliput 7" Touchscreen:
Pros:
1. alot of people are using so it cant be bad...also lots of complaints though
2, remote included to adjust screen (this is important if i take casing off)
Cons:
1. the case outside edges arent straight, bottom is rounded. Wouldnt look good on my dash with the case and buttons.
2. Case color is isnt black
3. alot of people are reporting problem with their lillys
4. $279.99
Xenarc 7" Touchscreen
Pros:
1. Has square edges if i decided to use the casing and its black.
2. Although not used as widely (b/c of $$$) the reviews are all GOOD
Cons:
1: $399.99...cost more than my 17" LCD!!!
2. no remote
3. no tutorials on how to disassemble LCD from case
4. want to stay away from b/c of price unless you guys with experience say i will be disappointed with the lilliput or others.
SP7 or starvision touchscreen
Pros:
1. $249.99 (cheapest of the 3)
2. Square edge
3. Remote included
4. Black Casing
Cons:
1. Probably not good a quality, esp. when sun is out
From the 3 i only have dimensions for the Lilly (from "searching") and it is too big with the case on for the double din and too small without the case.
Any of you guys that have installed a LCD into your dash have any idea or PICTURES AVAILABLE???
Here is the picture of where i want to mount the LCD...I think i want it permenantly there and not be easily removable, not worried about being broken into yet
thanks for looking!!!
sanbas is offline   Reply With Quote
Old 10-07-2004, 10:35 PM   #2
CustomZ02's Avatar
CustomZ02 is on a distinguished road
I used a lilliput 7inch on my double din. I just cut off the bottom part where the buttons were and it fit like a charm. So glassing and bondo makes it look nearly stock. Heres a pic of how mine turned out. And I havent had a problem with my lilli yet. Cept for when I installed it wouldnt power up but that was due to some dirty connections with all the dust I had.
Starting new project. After some jackass broke in and stole my screen.
CustomZ02 is offline   Reply With Quote
Old 10-08-2004, 11:08 AM   #3
sanbas's Avatar
oh thanks that helps alot!!!
my sister has a civic with the exact same interior...ill take a look at hers so i can get a before and after of the work u did.
Old 10-08-2004, 03:21 PM   #4
CustomZ02's Avatar
No problem
Old 10-08-2004, 03:39 PM   #5
heypachuco's Avatar
heypachuco is on a distinguished road
Lilliput makes some of the Starvision monitors.
heypachuco is offline   Reply With Quote
Old 10-08-2004, 03:40 PM   #6
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Pros:
Cons:
4. $279.99
Can't speak for the others (although without casing I think they will all fit) but the Lilliput does fit without case.
www.carTFT.com do a black one.
I've had two my first was of ebay guy from hong kong, dodgy from start and has all but died, but it did go through a lot of taking apart and putting back together again while I was designing/building dash mount
my second is from above and so far (touch wood has been fine).
They have made some changes and I think the quality has improved.
Enforcer is online now   Reply With Quote
Old 10-10-2004, 07:01 PM   #7
Player_One is on a distinguished road
Speaking of carTFT.com, here's a comparison chart that also lists the dimensions...
http://www.cartft.com/carpc/catalog/il/382
Player_One is offline   Reply With Quote
Old 10-11-2004, 01:21 AM   #8
sanbas's Avatar
man thanks that page is very helpful!
been reading a few more threads about lilly vs xenarc...I really feel like buying the lilly would be regreful down the line. I am just going to hold my breath and buy the xenarc probably, but its gonna be hard to spend that much money on a 7" monitor.
This carPC project keeps getting more and more expensive!
Old 10-11-2004, 01:48 AM   #9
PaCMaYNE's Avatar
PaCMaYNE is on a distinguished road
dude no ****,, i thikn regardless wherever you buy your LILLIPUTO, its gonna be the same quality,, i have had 2 of the newer ones in the last 7 weeks ( i have *****ed about this in about 5 threads now) but i cant get over how weak it is,, i mean 2 screens,, both bull****,, the odds are def against you if you buy a Lilli,, im thiknin of trying thr sp7,, its just insane to throw 400 for a screen out there.. INSANE
throw a moon
heuvos vin chevos
PaCMaYNE is offline   Reply With Quote
Old 11-19-2006, 05:28 PM   #10
brad1011a is an unknown quantity at this point
That's why my ideal screen would be DEATACHABLE (very important where I live).
So just a detachable screen with inputs. All other electronics reside in the (hidden) car-puter and amplifier. I guess a button interface around the screen would be cool, and enough space behind for a slot-load, slim optical drive.
When (and if) all that's available I'll make the switch from a head unit/hard drive setup.
brad1011a is offline   Reply With Quote
Old 11-19-2006, 05:58 PM   #11
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
you realize this is 2 years old right?
DIN and Double DIN Dimensions/Standards kubark42 General Hardware Discussion 15 08-05-2009 02:39 PM
double din adaptor? 2 1-din devices in a double din space possible? ucidave General Hardware Discussion 3 09-17-2004 06:10 PM
anyone know how many DIN a 1998 jeep grand cherokee laredo is? Nav_Attack General MP3Car Discussion 2 09-08-2004 07:12 PM
1 DIN, 1.5 DIN, 2 DIN, what's a guy to do? Chairboy LCD/Display 21 06-08-2004 02:40 PM
Help me understand PC in a DIN chassis cproaudio General Hardware Discussion 12 06-11-2003 11:51 AM
