Old 10-07-2004, 10:51 PM   #1
MSUC5Vette is on a distinguished road
8" Lilliput adds noise to my stereo
When my LCD is turned on I get noise through my FM stereo.
I have an FM modulator, but even with the modulator turned off I get noise if the LCD is turned on. When I run the sound through my computer it is worse.
I have also noticed it gets really bad when my wireless PCMCIA card is plugged into the laptop.
Has anyone else had this problem?
How can it be solved.
I have the factory radio in an '04 Malibu Maxx, the modulator is connected to the fuse box. The Lilliput is connected to the cig plug using the supplied Lilliput cable w/ egg thing.
The computer is connected to the same power fuse as the modulator using a car laptop power adapter.
MSUC5Vette is offline   Reply With Quote
Old 10-08-2004, 12:38 PM   #2
markgm is on a distinguished road
I have the 8" powered directly from my ITPS without any noise. I have my screen directly under my radio too, so while I don't have a solution, I can tell you should be able to fix it.
markgm is offline   Reply With Quote
Old 10-10-2004, 12:49 PM   #3
DeltaFX's Avatar
DeltaFX is on a distinguished road
Sounds like a grounding problem...
DeltaFX is offline   Reply With Quote
Old 10-11-2004, 04:33 AM   #4
euro320i's Avatar
euro320i
A lot of installs in this forum use 12vlts from the DC-DC converter.. mostly it is because the grounds are taken from different point on the chassis - in your case sounds like you have a ground off the ciggy..change the ground - prefferably to a common one. good luck
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
euro320i is offline   Reply With Quote
Lilliput egg noise, solutions? johnnyutah36 General Hardware Discussion 6 08-24-2004 02:24 AM
Noise in Lilliput from HDD zvi LCD/Display 5 07-14-2004 01:17 PM
Strange problems when hooking my pc to stereo, very low noise tjb1231 Car Audio 9 06-22-2004 02:24 PM
Lilliput causing engin noise eazyrog LCD/Display 10 06-07-2004 09:58 AM
Lilliput 8" Touchscreen Display Randomtask LCD/Display 6 02-06-2004 02:12 PM
