Old 10-14-2004, 05:39 PM   #1
800 x 600 Xenarc resolution help!
I can't seem to get my screen to get the 800 x 600 reso without losing the taskbar. I have installed the drivers that came with my Epia M-10K board and set the bios for 8x6. Anyone else had similar issues and fixes..
Google is offline   Reply With Quote
Old 10-14-2004, 05:43 PM   #2
pip
pip's Avatar
I'm guessing that on the xenarc, just like my lilliput there is an auto-adjust for the screen in the on-screen menu somewhere. That should fix it.
pip is offline   Reply With Quote
Old 10-14-2004, 05:45 PM   #3
try changing you refresh rate to eith 60hz or 70hz or 75hz
live2themaxuk is offline   Reply With Quote
Old 10-14-2004, 07:46 PM   #4
Agreed
Kefka_Killer.owns(you);
kefka_killer is offline   Reply With Quote
Old 10-14-2004, 07:50 PM   #5
I had the same problem Refresh rater fixed it for me.
voidunknown is offline   Reply With Quote
Old 10-14-2004, 08:25 PM   #6
bosstone74's Avatar
Please Let Us Know If It Works!
BossTone74
bosstone74 is offline   Reply With Quote
Old 12-03-2004, 12:22 PM   #7
Yep , setting the refresh rate to 75 fixed the problem for me.
Acid burn is offline   Reply With Quote
Old 12-03-2004, 12:43 PM   #8
Yeah but you will get annoying lines across the screen from time to time. It does this phenomenon on its terms not yours. Its random and ITS ANNOYING. i cannot find a way of fixing it. Seems the xenarc doesnt like 800x600 x60hz or at 75hz. At 85 it spazzes and says go away. You may even see a ghost image if you lucky. ROLL ON 800x480 driver VIA. . . .
is there any way to stretch the Brushed Metal skin to 800 x 600 bertybassett FrodoPlayer 10 11-01-2004 08:28 AM
Resolution problem with Xenarc 700YV lookinco LCD/Display 6 09-20-2004 04:12 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
best 16:9 resolution for xenarc 700tsv? 00CericaRuss LCD/Display 19 01-19-2004 02:04 PM
VIA EIPA 800 to output 16:9 resolution rmjjensen LCD/Display 3 11-18-2003 05:15 AM
