Old 10-28-2004, 03:54 PM   #1
Use a smart CRT instead of LCD
If space is not an issue would a CRT be better than a LCD as far as glare, brightness, and viewing angle? It probably would be cheaper.
What would be the disadvantages besides size and weight? Would power consumption be much more?
geaux is offline   Reply With Quote
Old 10-28-2004, 03:58 PM   #2
HybridFox's Avatar
i would think that power consumption will be horrible. not to mention heat, somtimes my crt gets so hot i ponder the idea of cooking off it
HybridFox is offline   Reply With Quote
Old 10-28-2004, 04:19 PM   #3
I got the rhythm.
Danceheaven's Avatar
Power consumption is amazinly several times higher
a typical 7 inch tft i believe is around 8 watts, a 15 inch panel is 30-40 watts, a 15" crt is around a 100 watts,
apart from that brightness does normally tend to be brighter, i would say that crts will not like the bumpy rite however, youll proberly find that the gun keeps fallen apart inside and that u loose R,G,B ocassionally due to the vibrations
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
Danceheaven is offline   Reply With Quote
Old 10-28-2004, 04:35 PM   #4
mindscream's Avatar
On a trip to Mendelsohn's I picked up a 6" B&W VGA monitor that was setup for 12v. It gets warm, but definitely not hot enough to be any worry. No touch screen on it, but the company that made it (who's name eludes me ATM) also had touchpad overlays for it...
Just FYI
Mind Scream out
mindscream is offline   Reply With Quote
Old 10-28-2004, 07:45 PM   #5
I remember on Knight Rider, Kit had a CRT. Go for it! David Hasselhoff styles!
Player_One is offline   Reply With Quote
Old 10-30-2004, 09:43 AM   #6
GuiltyLionel's Avatar
Well built CRT's are surprisingly strong, but still probably not viable in a car (except for smaller <10" variants). Despite taking a good chunk more power, and a good chunk more space...if properly installed you'd probably have no trouble. If you consider that most commercial jets still use CRT projectors (and then consider the terbulence) you can throw a lot of shock at them. However, I reckon its probably easier in a car to get a good picture from an LCD compared to CRT considering the totally analog nature of a CRT and its unwillingness to sit near any magnetics without ruining the scan.
$0.02
GuiltyLionel is offline   Reply With Quote
Old 10-30-2004, 10:27 PM   #7
eugenen's Avatar
I cheap CRT monitor is also sensitive to the cold. I had to replace the dumb terminal in a dispatch center years ago, took the new one out in the bed of my truck on a cold day and it powered up dim and blurry. I ended up pulling the board out of it and swapping with the one from the dispatch center since that was faster than waiting for it to warm up. got it back to the shop and left it sit until monday when I repaired the pcb and it worked fine since it had thawed out. I had a cap on my truck so it was protected somewhat but still cold.
eugenen is offline   Reply With Quote
Old 10-31-2004, 01:40 AM   #8
BiGGy's Avatar
At least your car will be warm and toasty
BiGGy is offline   Reply With Quote
Old 10-31-2004, 12:17 PM   #9
BiohazrD's Avatar
Assuming you had a way to diffuse the heat.
Quick! To the Popemobile!
BiohazrD is offline   Reply With Quote
getting laptop to shut off LCD with CRT on robr LCD/Display 2 04-29-2004 03:00 PM
Video is good on crt..bad on lcd Chronic13 LCD/Display 10 08-27-2003 08:08 PM
will constant image damage LCD screens like CRT screens? cproaudio LCD/Display 5 07-01-2003 09:25 PM
Kodak Smart LCD Frame Astaroth LCD/Display 14 10-29-2002 06:36 PM
FS: 15.4" TFT LCD w/ analog RGB input, 200nits, 1280x1024x16million, 12v DC input Mad Jad Classified Archive 5 08-20-2002 09:32 PM
