Old 10-28-2004, 07:50 PM   #1
Player_One is on a distinguished road
Question Does Xenarc use a DFP to VGA cable?
Just came across some DFP (Digital Flat Panel) to DVI (Digital Visual Interface) cables. Saw a DFP cable with a male end that looks like it will fit in my 700TSV.
Was wondering if my Xenarc would be able to use those. But then would I lose the analog and sound input? :S
Player_One is offline   Reply With Quote
Advertisement Sponsored links
Old 10-29-2004, 03:00 AM   #2
Raw Wave
Confused's Avatar
Confused is on a distinguished road
The newer Xenarcs do use the DFP connectors. However, I don't know how they are wired up within the connector to the screen, and you will also lose your AV inputs, as well as touchscreen connections.
You can get replacement cables from Xenarc. That would probably be your best bet if you need a new cable.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 11-06-2004, 02:40 PM   #3
What sort of cables did the older Xenarcs use? VGA connector?
Old 11-08-2004, 04:27 AM   #4
Raw Wave
Confused's Avatar
They used some really flimsy 15 pin connector that kind of "hooked in" to the screen, but if you moved it too much it had a tendancy to break!
Garry
www.aimee.cc
VGA Cable causing engine noise sq_geek Car Audio 19 12-28-2004 12:47 PM
Xenarc 700y Vga Cable pinox LCD/Display 0 10-12-2004 03:53 AM
How should I extend the VGA wire (Xenarc LCD) SpeedFreak03 LCD/Display 7 06-16-2004 11:37 PM
Fuzzy output using long VGA cable... sq_geek LCD/Display 3 06-11-2004 08:37 AM
Xenarc VGA or Composite GTPmp3PC LCD/Display 4 01-14-2003 11:15 AM
