Old 11-01-2004, 08:27 PM   #1
modding lilliput 1440*234 ???
is it possible to mod a 1440*234 lilliput (non vga) like psone display?
is it possible to conect vga cable to that lcd television?
(it has also a composite input, and it has rgb pixels (3*480=1440) )
and another question; i have a s-video - composite converter cable..
if i can't connect my lcd display to vga, how should i connect my computers video out to the lcd display
with long "long s-video cable(~4m) + svideo to composite converter" or "long composite cable (~4,5m)"
thanks for the answers...
zinzinzin is offline   Reply With Quote
Old 11-02-2004, 09:04 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
1) No. You can't mod an LCD to produce higher resolution because the number of pixels is fixed.
2) Not directly. You'd need either an RCA Composite-VGA adapter or a video card that has TV-out (either SVideo or composite)
3) Experiment and go with whichever gives you the best output quality. Mind you, VGA-RCA/SVideo typically results in marginal quality at best.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 123 11-06-2008 07:05 PM
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
