Mine does, I'm probably going to wire it to the Opus when I get it back. It's a bit annoying to have to turn the LCD back on. If you've got your Lilliput wired to an accessory lead (a lead that supplies +12v when the key is in both the accessory and run positions, but not in the crank position) then it has nothing to do with voltage drop. Accessory leads supply no current during crank, this is to supply the starter with the maximum required current to turn over the engine. Wiring to the Opus is probably the best solution, then it will be on whenever the PC is on.
