Quote: Originally Posted by phatbenny
Thanks motorcity
I think I have all the cables I need.
Looks like the ribbon cable and the power and the power for the lcd come from a small circuit board which plugs into a 44pin connector on the mpotherboard. Is this going to be the LVDS module?
What is an LVDS module?
I noticed that the VIA boards have LVDS as an option. Is this the name of the connection point on the board?
Is it an option as in you have to specify you want it or does it come on certain models?
If so does anyone know which models it comes on?
Sorry about the flow of questions. Just trying to learn
Cheers
Ben
Ben,
LVDS stands for Low Voltage Differential Signal.
the are 2 types of signals that lcd panels use.
LVDS as mentioned, and TTL.
lcd panels require controllers to seperate these signals into readable images.
on a mainboard that has a built in lcd controller, you simply connect a pre-configured cable from the board to the panel.
LVDS is great for distance, and TTL is less costly, but limits the distance between panel and controller.
the 44 pin connector on your board is the lcd controller connector, but is most likely TTL level signals. It may be LVDS, but I did not look at the specs of the board you mention.
the lvds option is the connector that goes to the lvds (or rgb) module, that then connects to the lcd panel via a cable.
here is a link to an epia with the lvds option onboard:
http://www.directron.com/epiam10000l.html
here is a link to the lvds module that attaches to the board:
http://www.computergate.com/products...odcd=B7VLVDS01
here is a link to the rgb module, which I am currently making cables for:
http://www.computergate.com/products...rodcd=B7VRGB01
here is a link to a press release of a company who has the deep pockets to make the cables:
http://news.designtechnica.com/article2422.html
you can bet that they won't sell a cable without a panel, and I am sure they will be expensive.
