Old 11-16-2004, 02:27 PM   #1
Tony S
Need Xenarc w/touchscreen internal cable help!!
I took apart my Xenon to replace the internal fuse. Now I've got a problem with connectors. The screen is almost 1 year old, has the t/s and vga.
Can someone please verify where the 4-conductor cable goes from the white 4-pin connector where the vga connector is....where does the other end go? I can't remember. I thought it goes to the white connector on the little touchscreen/USB card, but that's got 5 pins. I don't think I misplaced the cable but the cable I have is 4pin to 4pin. The cable will fit into this connector but it's going to be off by one pin. Can someone either confirm of maybe have a pic already of their Xenarc's w/touch board? Thanks!
P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
Tony S is offline   Reply With Quote
Old 11-16-2004, 02:36 PM   #2
ryuandwings's Avatar
ryuandwings is on a distinguished road
Can someone please verify where the 4-conductor cable goes from the white 4-pin connector where the vga connector is....where does the other end go? I can't remember. I thought it goes to the white connector on the touchscreen/USB card that sits on top of the big cpu, but that's got 5 pins.
I don't think I misplaced the cable but the cable I have is 4pin to 4pin. The cable will fit into this connector but it's going to be off by one pin. Can someone either confirm of maybe have a pic already of their Xenarc's board? Thanks!
Check digitalww site. I remember seeing photo of Xenarc module.
I will look for link later.
ryuandwings is offline   Reply With Quote
Old 11-16-2004, 02:42 PM   #3
Tony S
Will do. Thanks.
Old 11-16-2004, 02:51 PM   #4
Tony S
This appears to be the same touch module I have in the Xenarc:
http://www.digitalww.com/images/controler_front.jpg
HAA!! I JUST FOUND THE PIC I NEEDED! http://www.digitalww.com/images/VGAM_assembeled3.JPG shows that the connector, which IS the 4-conductor cable, goes into the 4 right-most pins on the touch card's connector! Yeah baby! I didn't think of digitalww. Thanks for pointing me there, bro!
Old 11-16-2004, 02:54 PM   #5
No problem.
Does Xenarc use a DFP to VGA cable? Player_One LCD/Display 3 11-08-2004 04:27 AM
Xenarc 700y Vga Cable pinox LCD/Display 0 10-12-2004 03:53 AM
Laptop Internal Connector Cable?? amessana General Hardware Discussion 1 10-01-2004 03:45 PM
Xenarc 700TSV cable broken. ripper Input Devices 1 04-25-2004 06:03 AM
Xenarc AC/DC cable Sunglassesron LCD/Display 2 10-02-2003 04:15 AM
