Old 11-17-2004, 12:39 AM   #1
Power Source for Xenarc
Hey guys,
Just wondering where are you guys getting your power from for the monitor. I have my Opus in the trunk so is there a better place to get power? Thanks.
legend5761 is offline   Reply With Quote
Old 11-17-2004, 03:32 AM   #2
binary.h4x's Avatar
Regulated source from the battery.
binary.h4x is offline   Reply With Quote
Old 11-17-2004, 09:58 AM   #3
Other than using the PC's power supply you can use your car's power. There's are problems doing it this way, and you may shorten the life of your screen. See my reply about using a timed relay here:
http://www.mp3car.com/vbulletin/lcd-display/36427-using-relay-switch-lilliput.html
P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
Tony S is offline   Reply With Quote
Old 11-17-2004, 05:41 PM   #4
Change's Avatar
I'll be using one of these: http://focus.ti.com/docs/prod/folders/print/pt5071.html
Change is offline   Reply With Quote
Old 11-17-2004, 10:53 PM   #5
For the Xenarc, there is no need to regulate the power source. I have my Xenarc directly connectd to my Accessory lead so whenever I turn on the car, it turns on as well. Been doing this for 6 months no without any issues.
DaRacerz is offline   Reply With Quote
Old 11-19-2004, 12:56 PM   #6
Yeah, that regulator's nice, but $$ and hard to get locally unless you get lucky. Instead of that, and the 7812, I picked up a regulated laptop dc/dc convertor. It's already got the correct sized barrel power connector for the screen and I just hardwired it into my acc lead. I wouldn't go unregulated to the screen no matter what people tell me here.
Old 11-19-2004, 01:10 PM   #7
Raw Wave
Confused's Avatar
Run a cable from the Opus, it's going to give you the best input. The Xenarc does have internal regulation (11-24V) but I prefer giving it a constant 12V (as you car can drop below 11V with the engine off or during cranking)
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 11-19-2004, 03:39 PM   #8
Not necessarily, if your run will be >4' then there's more likely a chance of picking up interference on the power line. Your best bet then is to use a filter to clean up the power signal. My Xenarc is running perfectly hooked to the regulated power cord attached to my acc line. In fact, I dare say it's a cleaner picture because of the shorter run and the fact that the power cord has a built-in filter.
Lilliput Power source needed R3l0ad LCD/Display 6 01-10-2004 10:28 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
PC power button problem BMp3W Power Supplies 4 10-12-2002 03:36 AM
Here's an alternative power source.... A Boy and his Miata General Hardware Discussion 7 11-21-2000 12:44 PM
About a power source SuperAJ General Hardware Discussion 5 08-04-1999 08:41 PM
