Old 11-18-2004, 02:58 PM   #1
crash893 is on a distinguished road
anyone put a lcd in a gauge pod?
i was wondering if anyone ever put a lcd display in a gauge pod?
or mabey even a vacume display
i wanted this as a aux display for my main display ( if its to bright or if i fell turning of the display)
i was hopeing to display obd-ii , mabey track info, other stuff i cant think of.
crash893 is offline   Reply With Quote
Old 11-18-2004, 03:22 PM   #2
SWC
SWC is on a distinguished road
I haven't done this yet but I am planning on doing this on a 65 benz I got and I was planning on doing this. Only thing I haven't figured our which might put a wrench in the plan is how to get the speed of the car to be acurate since this was before obd was even thought about. GPS isnt a viable solution since it varies and isnt 100% acurate. I can't take the change of the GPS being wrong saying im doing 55 when im really doing 80. If I cant get a viable solution with PC I am going to use instruments from www.dakotadigital.com
SWC is offline   Reply With Quote
Old 11-18-2004, 06:15 PM   #3
you could do a speed sensor the car should have one
at the very least you could wire tie a magnet to the axel and put a sensor to read the pulses
measure out a mile in pulses / time vola
Old 11-18-2004, 06:26 PM   #4
Chairboy's Avatar
Chairboy is on a distinguished road
GPS speed indication is very accurate, btw. Far more accurate then the mechanical gauges in most cars. Position, not as accurate. Altitude, far from accurate. But speed, yeah.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Old 11-18-2004, 07:20 PM   #5
eCar™'s Avatar
eCar™
Not if you want it to display your speed anywhere close to real time. If you let it average your speed for several seconds, it will be very accurate.
eCar™ is offline   Reply With Quote
Old 11-18-2004, 07:59 PM   #6
thread jack aside
does anyone know a good usb lcd or vcd that fit in a gague pod
Old 11-18-2004, 08:15 PM   #7
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Quote: Originally Posted by crash893
thread jack aside
Matrix Orbital + LCDC. I'm a LCDC programmer What GPS ap are you going to be using?
0l33l is offline   Reply With Quote
Old 11-18-2004, 08:26 PM   #8
none yet
i was going to have it be usb and run it off the computer rahter than directly from a devices
Old 11-18-2004, 08:36 PM   #9
My Village Called
0l33l's Avatar
none yet
Yeh, Matrix Orbital LCDCs need a computer, and LCDC is a very good program for that Control over winamp, limited support for WMP, etc
Old 11-18-2004, 09:36 PM   #10
what is the diffrences between lcd and the lcdc?
Old 11-18-2004, 09:52 PM   #11
My Village Called
0l33l's Avatar
LCD = the thing that displays stuff. LCDC = software that runs the LCD. LCDC supports Matrix Orbital displays, which are USB
www.lcdc.cc
Old 11-18-2004, 10:01 PM   #12
SWC
The speed sensor on the car is a cable tht screws into the back of the cluster then connects to the transmission so that would work. but I will more than likely being going with a more modern engine/tranny combo probably a small block chevy so I am sure I can get something to work with that.
Old 11-18-2004, 10:10 PM   #13
My Village Called
0l33l's Avatar
Anyway, if you get a Matrix Orbital LCD and LCDC, I'm pretty sure that I would be able to whip up some plugin that uses Ninja Monkey's D3 frontend and gets its speed and displays that data on the LCD
Extending your laptop's LCD cable: FAQ Yuriy LCD/Display 15 11-25-2008 03:06 PM
graphic LCD or PSOne LCD hannibal LCD/Display 50 09-26-2004 09:40 PM
Where would you put an LCD in this dash? redbeamer Fabrication 11 08-10-2004 02:03 PM
Mounting motherboard in WRX gauge pod housing.. Giuliano General Hardware Discussion 0 07-19-2004 10:01 AM
8.4" Touchscreen LCD, 7" Wide LCD & portable DVD player with TV Tuner nolmscheid Classified Archive 4 03-16-2002 02:32 AM
