Old 11-22-2004, 11:57 PM   #1
DWW-7VGA questions
hey, ordered one of these from Armen. in prep for it coming, i need to know what the hookups are so i can order the cables/connectors. what type of USB cable will i need coming off my USB hub? does it just have a female DB15 vga input? an electronic copy of the manual would be the best if it is around, i couldn't find it.
Craig
Craig W is offline   Reply With Quote
Old 11-23-2004, 12:43 AM   #2
There's a standard male VGA connector of the type one would connect to a VGA card, a standard USB plug of the type one would connect to a USB hub or computer, three RCA jacks which appear to be inputs which I have never used, and bare wires for the power. It's quite normal stuff, you just need a VGA extension cable and a USB extension cable.
wierdo is offline   Reply With Quote
Old 11-23-2004, 01:37 AM   #3
Weirdo, thanks buddy.
so basically, i will need a VGA extension cable with female on one side and male on the other.
for USB, is it a male to male "A" cable?
thanks again.
Craig
Old 11-23-2004, 04:10 AM   #4
Change's Avatar
For the USB cable, you may want something like this: http://www.ramelectronics.net/html/CAB-USB-6-16.htm
USB spec says about 16 feet maximum between active components...
You can also use a USB hub if you want, probably costs about the same.
Change is offline   Reply With Quote
Old 11-23-2004, 04:22 PM   #5
You need an extension type USB cable (female to male) like the one to which Change posted a link.
Old 11-23-2004, 04:31 PM   #6
thanks guys, much appreciated! now i can get going ordering stuff..
Craig
Lots of questions.. long post. rach Newbie 8 11-13-2004 11:53 PM
ODB-II Questions quickshot56 Engine Management, OBD-II, Engine Diagnostics, etc. 10 10-29-2004 10:10 AM
starting my first carputer project, have some questions ssa_whiskey General Hardware Discussion 0 02-24-2004 03:43 PM
Additional questions about LCDs: Is 400 nit too bright? khiser0001 LCD/Display 3 05-06-2003 08:13 PM
starting project soon, questions.. tekknikal General Hardware Discussion 1 05-28-2002 07:47 PM
