The MP3car.com Store
Thread Tools Display Modes
Old 11-29-2004, 04:24 AM   #1
NiN^_^NiN's Avatar
Vehicle: 94 Ford Probe GT
My Photos: (2)
Building a motorised screen without motors???
Ok guys im building my own LCD holder but it will work like a motorised LCD but it wont have motors.
The basic idea is to make a LCD slide out and up then u must manually fold the LCD down and push it back in when done.
So what im doing is building a case for this to slide out and open up.
The theory behind this is SPRINGS yeah im not crazy :P
What happens is when the LCD is pushed inside the case the spring streches so when u push the button to open the LCD the spring contracts and slides the LCD out of the case.
Ok so the spind just slides the LCD out right?
Then we have another spring which pulls the top of the LCD backwards to the case ro open set the LCD in view.
There will be a small wheel with foam on it at the top of the case so the LCD slides out smoothly and then when the end finally gets out it will angle the LCD so u can view it.
I will start building this soon and yes it will work some basic testing has been done and i have thought bout it all like slowing the speed the LCD slides out etc.
So what do u guys think?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Sponsored Links
Old 11-29-2004, 04:35 AM   #2
rum
rum's Avatar
Vehicle: Audi A4 1.9TDI 1996
My Photos: (0)
I say: nice project! But I have one question... The distance between the screen and your dash... won't that be much? I like your idea on using springs, I have been thinking about this too...
rum is offline   Reply With Quote
Old 11-29-2004, 04:42 AM   #3
My Photos: (0)
Hmm, nice one!!
My question would be how well would the springs work when it's coming up?
It's not gonna be smooth right? You'll need to push it beyond a point before the springs kick in and then it's gonna just suddenly spring up.. I think you need some way of dampening it... LEGO technics hydrolics?
DimensionZero is offline   Reply With Quote
Old 11-29-2004, 04:52 AM   #4
NiN^_^NiN's Avatar
My Photos: (2)
Yeah iv got a way to dampen it.
When the LCD slides out the Spring will be very tense what will happen is there will be a rail on the part that slides out which is going to be connected to alot of cogs which slow it down as it slides out.
I don't know how to draw it im probably not explaing it right
But the sliding out will be smooth cause of the cogs then the LCD will angle up pretty smoothly but i need to work that out a bit more.
Also the space between the dash and the LCD won't be that much as i plan to have it in the dash further and a fake cassette face so no1 will steal it :P
Or i might make a front which looks like the face has been removed so they wont bother trying to get it.
You could just use a OLD cdrom drive to slide the LCD out then the spring to make the LCD angle up
Did I actually answer your questions? lol
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 11-29-2004, 11:29 PM   #5
My Photos: (0)
have you checked out digital world wide? they have the DIN casing already built, springs and all....
WhiteRabbit is offline   Reply With Quote
Old 12-05-2004, 06:30 PM   #6
NiN^_^NiN's Avatar
My Photos: (2)
Does the LCD automaticlly slideout and swivel up with the springs?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 12-05-2004, 06:59 PM   #7
choyak's Avatar
Vehicle: 2004 Toyota 4Runner SR5
My Photos: (0)
are you sure that the springs would slide the LCD out rather than shoot it out. It needs some sort of a damping mechanism like perhaps a flywheel after the cogs.
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
choyak is offline   Reply With Quote
Old 12-05-2004, 07:17 PM   #8
tekkno's Avatar
My Photos: (0)
But not in stock......
graham:-)
tekkno is offline   Reply With Quote
Old 12-05-2004, 07:43 PM   #9
NiN^_^NiN's Avatar
My Photos: (2)
Yeah it will slide out not shoot out I'v thought it all through just need to get some parts and start building.
The spring slides the LCD out which is connected to the Cogs which is connected to the damping mechanisn so it wont just spring out and hit u in the head
When i have it made and have it all working properly i'll put up a lil how-to on building 1.
I could just build a motorised 1 if i wanted to but i dont have enough time to do that then build a PIC to control it.
Altho anyone could build a motorised 1 as u can get PIC kits for like $20 then u just need to get the right motor then hook it up through a pulley type of system
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 12-05-2004, 08:41 PM   #10
My Photos: (0)
http://www.digitalww.com/indashhousing.htm
Sponsored Links
Old 12-05-2004, 09:34 PM   #11
choyak's Avatar
My Photos: (0)
Quote: Originally Posted by WhiteRabbit
I don't think so
EPIA MII-12000
Hitachi 60GB
Carnetix P1260
Old 12-06-2004, 01:14 AM   #12
NiN^_^NiN's Avatar
My Photos: (2)
Parts List:
Ok here is the parts list
1 x C-73 Utility Ext Spring (7.137 x 47.625 x .635mm)
2 x C-31 Utility Ext Spring (11.126 x 38.1 x .711mm)
1 x 7" LCD VGA/Composite
1 x 1-DIN Housing (old stereo etc)
Thats it so far will be updated with the rest when i start it some more
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 12-06-2004, 02:50 AM   #13
My Photos: (0)
out of stock doesnt mean out of production!
*shrug* just wait awhile or call up armin and ask when he will get the next shipment in. itll be much easier and look a whole lot cleaner.....
Old 12-06-2004, 04:12 AM   #14
NiN^_^NiN's Avatar
My Photos: (2)
you do know it cost $150+ for me cause im in australia its easier for me to build 1 and i can make it look as good as that in dash housing
Besides building it yourself is part of the fun
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Old 12-06-2004, 06:11 PM   #15
My Photos: (0)
good luck. some potential problems with that housing you can correct with your build:
if you have loud bass or drive faster than 25 miles an hour, the hinge chant support the screen's weight, so itll dip down over time. If you put a hinge on yours and make it a frictionfit so the angle is adjustable, make it nice and friction-y
make sure you route your wires away from the mechanics, dont want to have those all clipped off!
thats all I can think of off the top of my head, im sure youve got everything covered. good luck!
Sponsored Links
Trackbacks are Off
Has anybody ever got lil/Xen screen to clock onto native res? ChrisC LCD/Display 5 04-30-2004 11:25 AM
What the....same screen? Good screen? Seabass General Hardware Discussion 4 03-30-2004 11:37 PM
Touch screen motorised VGA display. chenko LCD/Display 2 03-25-2004 08:07 PM
screen help XCURSN LCD/Display 2 06-24-2002 11:10 AM
Redant screen - widescreen, screen res, TV out??? Griffin_Dodd General Hardware Discussion 4 02-06-2002 06:09 PM
Sponsored Links
Ad Management by RedTyger
