The MP3car.com Store
Thread Tools Display Modes
Old 11-13-2005, 11:32 PM   #16
pasic's Avatar
Vehicle: Where To Start?
My Photos: (1)
as good an idea this is, better yet if you have a strong enough psu (atleast 150w) write the monitor directly into it and your shutdown controller, this will shut down and boot the entire system toghether - if you can best bet would be to use an extra cdrom or floppy connector coming out of the psu to power the screen (instead of splicing into the main atx connector to the mb)
-- reffering to the usb and touchscreen detection problem when screen shuts down before computer --
pasic is offline   Reply With Quote
Sponsored Links
Old 11-17-2005, 02:21 PM   #17
Viscouse's Avatar
Vehicle: 2003 Saab 9³
My Photos: (0)
Inside the 700IDT
If you are interested in what's inside the Xenarc 700IDT chassis, here is a thread with pictures of the inside of the cage (not the inside of the actual monitor).
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline   Reply With Quote
Old 12-29-2005, 04:41 AM   #18
Vehicle: 2002 WH II Statesman Caprice 5.7 A4
My Photos: (0)
Xenarc dimensions as it comes in the box
The Xenarc 700TSV casing dimensions as it comes in the box are:
Height: 125mm
Width: 195mm
Depth: 34mm
I couldnt find a post with these dimensions anywhere on the site and these are useful for people like me who dont want to remove the outer casing
WH Statesman Caprice CarPC
Mini ITX SP13000, 1GB RAM
40GB Hitachi Laptop HDD
Xenarc 7" Touchscreen
Dual Super 8" LCD headrest Monitors
Opus 150
Holux 210 GPS Receiver
Testing Phase :(
VYR8 is offline   Reply With Quote
Old 12-30-2005, 02:48 AM   #19
Mattkins99's Avatar
Vehicle: '01 Lemans Blue M5
My Photos: (0)
If you flip the touch controller ribbon, or are doing the mod in the first post and flip the data wires... don't worry (just did this a couple of minutes ago) recalibrate the touch screen and you're good to go.
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
Old 02-15-2006, 10:38 AM   #20
Lathinx's Avatar
Vehicle: 2001/Grand Am GT
My Photos: (0)
Quote: Originally Posted by live2themaxuk
DISCLAIMER: - I ACCEPT NO RESPONSIBLILTY FOR INJURY LOSS USING ANY INFORMATION SEEN BELOW.
It seems the Xenarc touchscreen isnt self powered and only comes on after the screen itself has had power given to it.
i have my screen turn off HARD when i pull my keyout, but my computer stays on until the opus turns it off softely, so the computer thinks ive pulled the touchscreen usb out. WHen it comes back on i get a Duuuuu-daaaaaa as if ive pulled it back in again (which in effect i have as i turn my screen on) and it messes up any visulisation i have running)
SO to solve this, you need to do what i have done below. Seperate the USB touchscreen from the Xenarcs 20 Pin lead.
The following assumes you know abit about electronics and have disassembled a xenarc/gain beforehand
1# Find a spare longish USB lead with a male end on it.
2# Cut and strip back the wire to expose the inner cables Positive Negative and the two signal wires.
3#Before you unplug the cable on the back on the xenarc linking the USB touchscreen board to the xenarc 20pin connector you may want to check the continuity of which connect is which and where it goes at the end of the USB plug. Note, you will not get a electricity flow through the V+ pin on the USB controller and the USB plug as that is in effect 'blocked' until you turn the screen on (which is why i am doing this)
4# Unplug the cable that links the xenarcs 20pin board to the USB controller board. Notice there are 5 PINS on the controller board but only 4 on the plug that plugs into it. WHen you plug the connector back it ensure it is biased more towards one side than the other. (see pic at the bottom)
5# Either cut the original cable linking the USB touch board with the Xenarc's 20pin board or find the same connector from elsewhere (like i did) and solder it up based on your findings in #3
6# notice the colours of the USB leads and the little connector. These colours and positions were correct for my situation but i cannot garentee they will be the same for you. They should be if all colours are followed in USB leads but i suggest you check and double check it with a continuity tester (multimeter) first
7# Individually insulate them up then insualte the whole lot to ensure a good strong join in the cable (fragile connectiond under there)
8# triple check all connections and connect to USB controller. Notice how it is more towards one side of the connector than the other, leaving one pin not used it the recieving connector block.
9# Fire it up (not literally we hope) and test with fingers crossed
10# Admire your work
I hope some of you will find this useful
good luck
Jamie
I got an easyer way to stop the beep...
Go to control Panel, goto Sound Under sounds, Turn off the Windows Connect sound and disconnect sound.
Just cuase I ask questions, doesn't mean I stop looking for an answer.
Grand AM GT
Plans:
7" touch screen
1.3 ghz laptop (win XP)
replacing the stock sound.
red ground effects
wireless keyboard, mouse and remote.
GPS,Bluetooth,Wi-FI,FM tuner.
Lathinx is offline   Reply With Quote
Sponsored Links
Old 02-25-2006, 07:53 AM   #21
Raw Wave
justintime's Avatar
Vehicle: 2002 Honda CR-V
My Photos: (0)
THIS THREAd IS FOR FAQS NOT FOR QUESTIONS!!!!!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 05-07-2006, 01:43 AM   #22
Vehicle: 2004 BMW 318i Sports Edition
My Photos: (0)
Xenarc Touchpanel Driver
I bought the new 5-wire Xenarc 700TSV.
The driver CD that comes with the package is Ver 3.2.4.
This driver does not work with XP.... the touch panel calibration software could not "discover" the touchpanel.
Go to http://www.xenarc.com/download.html and download a newer version of the driver and it works fine. I use the following driver:
win2000_XP.4.0.2.1929.zip
Although it says "beta" version, it works. It doesn not have the "shutdown" feature on the bottom taskbar though.
Merlion is offline   Reply With Quote
Old 05-15-2006, 10:25 PM   #23
-CM
Vehicle: 2006 Honda Ridgeline
My Photos: (0)
1020 Tsv
There are 2 bugs in the Xenarc 1020 TSV, the backup camera feature does not work properly. There is no upgradable firmware in these monitors so the problem can not be fixed without replacing the main board. The feature, as with most Xenarc monitors, automatically overrides the VGA channel with the channel 2 RCA input when there is a signal. It should then switch back to the VGA channel when the signal is gone.
Problem 1:
VGA is running, put the car in reverse and backup image appears from Channel 2 as it should => put the car in drive and it does not switch back to VGA (although randomly it does).
Problem 2:
VGA is off, put the car in reverse, the image appears correctly on channel 2. If VGA is given a signal while you are in Channel 2 the screen then scrambles. This happens every morning when I am backing out of my garage and my PC boots.
Xenarc said it was only an issue with the 1020 board. They also said it will be fixed in the next production run (whenever that may be).
Honda Ridgeline
Pentium M - 10.2" Screen
http://craigrmartin.googlepages.com
-CM is offline   Reply With Quote
Old 06-05-2006, 07:02 PM   #24
My Photos: (0)
For those that are looking for a pin-out for the daughterboard on the motherboard check this thread: http://www.mp3car.com/vbulletin/showthread.php?t=54758
silv3rman is offline   Reply With Quote
Old 08-16-2006, 07:13 PM   #25
My Photos: (0)
Thumbs up Replacement Housing
If you lose/break your plastic outer case, you can get a replacement directly from Xenarc for US $25 plus $6 shipping**. (700TS or TSV).
Simply call: 714-546-1018 ext 2 for Tech support.
**May not be accurate when you read this.
Geese is offline   Reply With Quote
Old 04-05-2007, 04:55 PM   #26
agiorgitis's CarPC Specs
My Photos: (0)
Does the Xenarc's have a service menu? How it can be entered?
agiorgitis is offline   Reply With Quote
Old 06-07-2007, 05:07 PM   #27
My Photos: (0)
Quote: Originally Posted by WiCKeD 5.9L View Post
Powerstrip settings for running your Xenarc in native 800*480 resolution & manufacturer's FAQ:
http://www.xenarc.com/faq.html#QA1
Q: How do I power my Xenarc using the molex plug on my power supply? (safer, regulated power)
A: Chop off the power connector of the included cigarette lighter adapter. The inner set of wires is your positive and the surrounding layer of wires is your negative/ground. Twist these into separate positive/negative strands.
Connect the positive strand to the yellow wire on a male molex connector. Connect the negative strand to either black wire on the male molex connector. Plug it in to one of the female molex connectors on your power supply and you should be good to go!
If you do not want to destroy the Xenarc's cigarette lighter adapter, you can also substitute any other power adapter that uses the same style plug. The wiring will most likely be a little different, but you still have a 50/50 chance of guessing the right polarity.
Whoever wrote this does not have a 1020TSV. Do NOT chop off the 12V adapter that came with that, because you will NOT find 2 wires inside. I made this mistake. Instead, you will find an outer sheath and inner wire, which will be impossible to connect to 2 wires. Instead, carefully take apart the 12V cigarette plug adapter and you will see the two wire ends. You must use those and if you screw up connecting them you don't get a another shot. I had to go to radio shack and get the same style plug and use that instead.
Also, you can use the house adapter that comes with it to check what the polarity is supposed to be, then check your setup before plugging it in.
pilavdzic is offline   Reply With Quote
Old 07-08-2007, 02:21 AM   #28
Vehicle: E46 M3
My Photos: (0)
sometimes screen orientation will get skewed horizontally to the left by approx. 3/4 the screen.
a fix for this is to change your refresh rate. default is 60, and xenarc screens support 60-85hz. i currently run at 75hz, no problems.
KaOsTiK is offline   Reply With Quote
Old 08-22-2007, 04:51 PM   #29
My Photos: (0)
Can someone please post the glass to glass measurements of the 840TSV Xenarc. Pics of the inside would be nice too.
I know, no questions, but once someone posts it then you can delete this I promise : )
changeip is offline   Reply With Quote
Old 10-26-2007, 05:52 PM   #30
altinono's CarPC Specs
altinono's Avatar
Vehicle: altima SE 05
My Photos: (7)
Short cable
hi
the cable that come withe the Xenarc 700TSV is very long for me
so i minimiz the cable
here is the pic that maybe will help some one
altinono is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Xenarc direct cause of audio noise- help! shidarin LCD/Display 5 04-19-2008 09:53 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Xenarc VGA Controller Features 1300mer LCD/Display 0 07-05-2004 12:46 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 06:38 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 03:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
