The MP3car.com Store
Thread Tools Display Modes
Old 12-01-2004, 01:52 AM   #1
9 Fingered Administrator
Lesbian
frodobaggins's Avatar
Vehicle: 1998 Ranger/1991 Sunbird
My Photos: (0)
FAQ: Everything you need to know about your Xenarc
This will be for the Xenarc/Gain screens.
You veterans post up.
This thread is not for questions.
Quit Posting in this %$@# Thread unless it's info
about Xenarc/Gain screens ! I've already deleted
several questions, comments, etc. Nobody cares
how glad you are this thread is here, etc.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Sponsored Links
Old 12-02-2004, 12:51 PM   #2
My Photos: (0)
How to: -Keep USB touchscreen on after you turn it off
DISCLAIMER: - I ACCEPT NO RESPONSIBLILTY FOR INJURY LOSS USING ANY INFORMATION SEEN BELOW.
It seems the Xenarc touchscreen isnt self powered and only comes on after the screen itself has had power given to it.
i have my screen turn off HARD when i pull my keyout, but my computer stays on until the opus turns it off softely, so the computer thinks ive pulled the touchscreen usb out. WHen it comes back on i get a Duuuuu-daaaaaa as if ive pulled it back in again (which in effect i have as i turn my screen on) and it messes up any visulisation i have running)
SO to solve this, you need to do what i have done below. Seperate the USB touchscreen from the Xenarcs 20 Pin lead.
The following assumes you know abit about electronics and have disassembled a xenarc/gain beforehand
1# Find a spare longish USB lead with a male end on it.
2# Cut and strip back the wire to expose the inner cables Positive Negative and the two signal wires.
3#Before you unplug the cable on the back on the xenarc linking the USB touchscreen board to the xenarc 20pin connector you may want to check the continuity of which connect is which and where it goes at the end of the USB plug. Note, you will not get a electricity flow through the V+ pin on the USB controller and the USB plug as that is in effect 'blocked' until you turn the screen on (which is why i am doing this)
4# Unplug the cable that links the xenarcs 20pin board to the USB controller board. Notice there are 5 PINS on the controller board but only 4 on the plug that plugs into it. WHen you plug the connector back it ensure it is biased more towards one side than the other. (see pic at the bottom)
5# Either cut the original cable linking the USB touch board with the Xenarc's 20pin board or find the same connector from elsewhere (like i did) and solder it up based on your findings in #3
6# notice the colours of the USB leads and the little connector. These colours and positions were correct for my situation but i cannot garentee they will be the same for you. They should be if all colours are followed in USB leads but i suggest you check and double check it with a continuity tester (multimeter) first
7# Individually insulate them up then insualte the whole lot to ensure a good strong join in the cable (fragile connectiond under there)
8# triple check all connections and connect to USB controller. Notice how it is more towards one side of the connector than the other, leaving one pin not used it the recieving connector block.
9# Fire it up (not literally we hope) and test with fingers crossed
10# Admire your work
I hope some of you will find this useful
good luck
Jamie
live2themaxuk is offline   Reply With Quote
Old 12-03-2004, 05:14 AM   #3
ramy_zohair's CarPC Specs
ramy_zohair's Avatar
Vehicle: 2002 Mitsubishi Magna
My Photos: (0)
Quick Start Manual
Here's a quick start manual for the 700TSV
Thanks to PatO
ramy_zohair is offline   Reply With Quote
Old 12-29-2004, 07:35 PM   #4
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
If installing the Xenarc after a Lilliput (or any monitor) change the refresh rate (in the control panel) to 60Herts FIRST.
It was an *itch to do this after installing the Xenarc.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 01-08-2005, 06:34 AM   #5
My Photos: (0)
Xenarc 8" Dimensions
Here are the dimensions of the Xenarc 8"
Props to Red GTI VR6
Old 01-08-2005, 06:35 AM   #6
My Photos: (0)
more:
Old 01-08-2005, 07:09 AM   #7
My Photos: (0)
7" Board (Internal) pic
This is for the 7" Xenarc
Thanks to Homebrew
The dimensions are :
LCD: 108mm X 171mm
PCB: 120mm X 118mm
(notice that the PCB is taller but narrower than the screen)
(the buttons are soldered on the same PCB)
Old 01-10-2005, 09:04 AM   #8
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
When taking apart your xenarc, be very careful if you remove the touchscreen controller. On one side there is a plug for a flat 4 pin plug for the touchscreen overlay itself, if you plug this in upside down, the touchscreen will work, but the orientation will be reversed. On the opposite side is a 5 pin plug that takes a 4 pin cable. This is can be a problem, make sure you plug the 4 pin cable into the touchscreen controller so the yellow wire is on the pin at the edge of the controller. The fifth pin is not used. Plugging this cable in wrong may damage the touchscreen controller.
StreetDeck.com Developer (I am Chuck)
Download the 30 Day StreetDeck Trial version!
Video Blog
god_of_cpu is offline   Reply With Quote
Old 01-10-2005, 09:05 AM   #9
Raw Wave
god_of_cpu's Avatar
My Photos: (0)
When installing the touchscreen drivers, make sure you run the setup.exe, don't try to install the drivers directly from the CD, the touchscreen will be detected, but it will not work.
Video Blog
Old 01-10-2005, 09:08 AM   #10
Raw Wave
god_of_cpu's Avatar
My Photos: (0)
If you do break stuff after taking your screen, xenarc is pretty good about selling you parts. You can get them by contacting someone in the sales department at xenarc. These prices may not be accurate at the time you read this.
TouchScreen overlay: $50
TouchScreen Controller: $50
Backlight Inverter: $50
Video Blog
Sponsored Links
Old 01-10-2005, 09:10 AM   #11
Raw Wave
god_of_cpu's Avatar
My Photos: (0)
The length of the internal cables in the xenarc is 6". This inclues the display ribbon cable and the multicolored backlight and touchscreen contoller cables.
Video Blog
Old 05-12-2005, 06:22 PM   #12
Raw Wave
justintime's Avatar
Vehicle: 2002 Honda CR-V
My Photos: (0)
(Quoted from another post)
The external Dimensions of the shroud are 8 3/8 X 5 1/2 X 1 3/8 (1/4 Inch bevel)
The shroud is molded to the shape of the 700 Series Xenarc Monitors and the monitor is simply pressed in place. As for the quality it's not bad. It'a standard plastic molded frame. I've seen better but it does the job very well. It also looks much better once installed. I've seen some people install them in a headrest and cover the shroud with the headrest material. This way you don't even see the shroud
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 07-06-2005, 12:58 AM   #13
Registered User
aoLhaTer's Avatar
Vehicle: 04 Infiniti G35 Coupe
My Photos: (0)
If you remove the ribbon cable make sure not to remove the brown clip fastener. I accidentally knocked the clip out and it broke making it impossible to reinsert the ribbon cable. To properly remove the ribbon take your fingernail and wedge it behind the clip and lightly work it out
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 08-03-2005, 10:15 PM   #14
WiCKeD 5.9L's CarPC Specs
Vehicle: 1998 Jeep Grand Cherokee 5.9L
My Photos: (0)
Powerstrip settings for running your Xenarc in native 800*480 resolution & manufacturer's FAQ:
http://www.xenarc.com/faq.html#QA1
Q: How do I run native resolution on an intel chipset if I do not have Powerstrip or Powerstrip fails to work?
A: You will need to use the intel embedded graphics drivers and program them for your LCD/motherboard combo.
Giulano's IEGD build for boards using the VGA port
852GM
852GME
845GV
855GME
915GM
915GV
945G
945GM
Giulano's IEGD build for boards with an LVDS port
855GME
915GM
945GM
This method will also work, for 855GME/865 boards using the IEGD 4.1 software.
You may need an earlier version of the IEGD software if you have an older board.
Q: How do I power my Xenarc using the molex plug on my power supply? (safer, regulated power)
A: Chop off the power connector of the included cigarette lighter adapter. The inner set of wires is your positive and the surrounding layer of wires is your negative/ground. Twist these into separate positive/negative strands.
Connect the positive strand to the yellow wire on a male molex connector. Connect the negative strand to either black wire on the male molex connector. Plug it in to one of the female molex connectors on your power supply and you should be good to go!
If you do not want to destroy the Xenarc's cigarette lighter adapter, you can also substitute any other power adapter that uses the same style plug. The wiring will most likely be a little different, but you still have a 50/50 chance of guessing the right polarity.
WiCKeD 5.9L is offline   Reply With Quote
Old 10-25-2005, 09:44 AM   #15
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
You can leave the internal speaker disconnected and the Xenarc will function normally.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Xenarc direct cause of audio noise- help! shidarin LCD/Display 5 04-19-2008 09:53 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Xenarc VGA Controller Features 1300mer LCD/Display 0 07-05-2004 12:46 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 06:38 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 03:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
