Old 12-02-2004, 06:43 PM   #1
rgardjr's Avatar
Any 7" VGA and Composite touchscreen monitors with trigger for reverse camera?
I spent some time searching and didn't find anything along the lines of Xenarc or Lilliput having a built in trigger to switch inputs for a reverse camera. Has any one come accross any. I've seen some composite screens that have this feature, but nothing with VGA/touchscreen. I was playing around with a Lexus GX470 last weekend that had this feature and I thought it was very cool.
'03 Sierra Denali
rgardjr is offline   Reply With Quote
Old 12-02-2004, 06:54 PM   #2
egeekial's Avatar
I'm not sure of the details, but you can use for carputer to do it instead of the screen.
2001 Nissan Altima SE
Shuttle FV24 / P3 1Ghz
512MB (2x256) PC133 RAM
40GB 7.2k RPM
WiFi / GPS / XM
Opus 150
Xenarc 700TSV
XP Pro (nLite) / Frodoplayer
egeekial is offline   Reply With Quote
Old 12-02-2004, 06:58 PM   #3
rgardjr's Avatar
I've read a little bit about using some of Frodos great applications to accomplish this via software using a net cam. The net cam is a little bit of a problem for me because I'll be mounting this on the tailgate/back of a pickup truck.
'03 Sierra Denali
Old 12-02-2004, 06:58 PM   #4
Raw Wave
rando's Avatar
@egeekial: The most common backup maneuver is right after you start the car. For most people, boot times are slow enough that by the time the pc is ready to play, they will already be done driving backwards. That's why people are looking for a direct hardware approach.
To answer the OPs question, there aren't any built-in triggers to do what you want. So far, I haven't seen any mods to do the trick either. You could build something that counts pulses on the video input button but without some sort of feedback mechanism, it would likely get out of sync -- and thus be useless. Perhaps somebody will hack around their Lilliput with a scope and fine a suitable point to attack this mod.
2004 4runner
rando is offline   Reply With Quote
Old 12-02-2004, 07:08 PM   #5
Yuriy's Avatar
Get one of those VGA boxes that will let you switch modes.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 12-02-2004, 08:46 PM   #6
Tainted Love
Cris's Avatar
What about this: http://www.cartft.com/carpc/catalog/il/395
It's supposed to automaticlly switch to the rear cam...
Cris is offline   Reply With Quote
Old 12-02-2004, 09:13 PM   #7
That would not cut it, it does not take VGA.
kingtut is offline   Reply With Quote
Old 12-02-2004, 09:26 PM   #8
Tainted Love
Cris's Avatar
Not sure if it will work either. I just ordered it, but, like the screen, it's not here yet. They said it would work fine...
How many VGA cameras do you know?
Old 12-02-2004, 09:39 PM   #9
I'm wondering if maybe you could use a shutdown controller... the "remote" input could be hooked up the the reverse lights or something similar and the atx-output hooked up to the "input" button of your screen. But I'm not sure if the "input" button accepts the same voltage as an atx pulse, or even if the shutdown controller delivers voltage or if it just shorts the 2 pins that are connected to it...
Also, I guess it would have to send 1 pulse when the line goes high (to switch to input 1) and then 2 when the line goes low (to switch to input2 and then to VGA). Just an idea... might work with some modifications.
Bobby Digital is offline   Reply With Quote
Old 12-05-2004, 06:41 AM   #10
ernie's Avatar
I think Xenarc has this abiliti. I read on the forums that it has video2 priority, so when there is signal, it cuts vga or video1 and switches to video2, so all you have to do is plug camera into video2 and power it from your rear light.
ernie is offline   Reply With Quote
Old 12-05-2004, 02:55 PM   #11
Arr wicked i just tried this. i didnt realise you could do it. There is an option called AV2 First. WHen you turn it on when ever it senses a singal on the AV2 line it will swap to it. Then when it doesnt it will switch back to whatever it was on before. PERFECT for my reverse cam. Im well chuffed. Cheers ernie, i wondered what that option did.
live2themaxuk is offline   Reply With Quote
Old 12-06-2004, 02:17 PM   #12
rgardjr's Avatar
Thanks! I might have to buy a new monitor.
'03 Sierra Denali
Old 12-08-2004, 04:46 PM   #13
My new Xenarc has Video2 option to power on with video signal.
Also you can get a device called a "Cheese Box", I picked up one on ebay for under $50. It is a VGA interrupt, so you can have your PC plugged into this box and the screen, then it accepts a composite video signal and pumps it into the screen. The only issue out of the box is that you need to rewire the on-off switch on the cheesebox so that it is momentary on based on your reverse lights... search the forum for cheesebox, there is a quick how to.
I bought mine back before when I was planning on a Lilli... but I made the jump - I figure I'm worth it... :-)
mgithens is offline   Reply With Quote
Old 12-08-2004, 06:55 PM   #14
rgardjr's Avatar
Thanks for the post! I did a little reading and it looks like this could potentially work for me. My one concern is that the Lilliput is flaky resynching after changing resolutions at times. I'd hate to spend the time to use the Cheese Box only to have to turn the Lilliput off/on when I get an over range message. Pretty cool to think that the input to the screen would be line doubled! Anyone whose used the Cheese Box/Lilliput want to chime in on how well this works?
'03 Sierra Denali
VGA vs RCA & Touchscreen vs other integsrtite LCD/Display 3 12-02-2004 07:07 PM
Alpine NVE-N077PS's RGB output to VGA input on 7" lilliput TS monitor? hsuca LCD/Display 0 09-27-2004 08:07 AM
Starvision 7" VGA touchscreen pictures/review NoPistonPC LCD/Display 22 08-31-2004 04:26 AM
vga -> composite -> vga (possible?) Nav_Attack LCD/Display 6 04-03-2004 12:38 PM
7" composite or 15" true vga lcd? cdm LCD/Display 3 11-26-2003 02:45 PM
