Old 12-05-2004, 11:18 PM   #1
Need picturesque PSOne LCD VGA modding diagram
Hey there.
I'm new here,... and to modding altogether.
I've trolled for a while, and I think you guys are AWESOME!!
Although I've looked at most of the PSOne LCD VGA mods, I still find myself hesitant to crack open my screen.
I'd love to hook up a PC to the screen,.... but first, I'll need to see exactly what to do.
Is there a step by step FAQ or PDF, that has explicit details in LAYMEN's terms????
If so,.. I'd really appreciate it.
Thanks so much.
drone8888 is offline   Reply With Quote
Old 12-05-2004, 11:30 PM   #2
Mage's Avatar
my option is it's not worth it after 8months I still dont have it working right and cost about $200 (G4 card mostily) could save my self time by just buying a lil for $250. if you still want to do it do a search for psone mage and you'll find lot's of info.
Peace
Mage
[size=-2]-=Cars=-
1998 Chevy Malibu Sedan, 4cyl Auto.
Mage is offline   Reply With Quote
Old 12-05-2004, 11:40 PM   #3
I don't understand???
Why wouldn't I want my PSOne LCD to accept VGA???
I got it for cheap,... and I'd like to start a hobby. Modding this screen is the perfect thing.
I'll do a search for your page,... but I don't know if you understood my request.
Thanks though.
Old 12-05-2004, 11:55 PM   #4
Mage's Avatar
it's a pain to set up it required only 1 of 5 video cards and lot's of this and that. mostly though it's alot of sodiering and configuring.
there's a good writeup under one of my post that tells you everything you need.
Peace
Mage
[size=-2]-=Cars=-
Old 12-06-2004, 01:21 AM   #5
It is very easy to do. I think it took me about 30min. to do. http://users.adelphia.net/~mowry/lcd.htm I hope this helps.
mymojo68 is offline   Reply With Quote
Old 12-06-2004, 01:38 AM   #6
My Village Called
0l33l's Avatar
People use VGA for better text quality.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 12-06-2004, 02:21 AM   #7
starfox's Avatar
If you're lazy like me, try just make a composite adapter first:
http://www.ucc.gu.uwa.edu.au/~starfo...sayako_lcd.htm
If that's good enough, you don't have to do the mod. I'm planning on just using a composite video in my car because running shielded VGA signals from my boot to where i want to mount the LCD is a pain in the arse and i'll probably pick up a lot of interference.
starfox is offline   Reply With Quote
Old 02-12-2005, 08:39 PM   #8
Thanks for the laymen's mod picture, for my PSone screens.
Is it possible to use a COMPONENT cable, to access better resolutions??
I tried playing my GameCube on the screen, using a stereo component camcorder cable, and a few female/female connectors,..... but of course,.. when I set me game to Progressive Scan, it doesn't work.
I imagine using components, it would,.... but there isn't really a component camcorder cable.
Any ideas???
Thanks.
Old 02-12-2005, 10:37 PM   #9
starfox's Avatar
You probably could use a component cable if you could seperate out the sync signal from wherever it is...
Old 02-15-2005, 01:42 PM   #10
btw, starfox, i followed your site for the vga mod, and for me i had to swap the red and green connections to get the right colour... (this was using matrixpc's c-sync circuit btw)
me and me lude is offline   Reply With Quote
Old 02-15-2005, 02:08 PM   #11
IMO, the wiring isnt too difficult. The part I am stuck on is configuring PowerStrip.
I need to network the carPC in order to adjust the Powerstrip settings with RealVNC.
My first carPC!
MP3/CD player
Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
Soon to actually find its way into the car!
hannibal is offline   Reply With Quote
Old 02-15-2005, 04:36 PM   #12
MySQL Error
MatrixPC's Avatar
Just for clarification, I didn't create the circuit. Someone else create it, and the schema is on the net for a while. Base on the schema, I draw it in ExpressPCB so that it is easy to read/follow.
If the video card can put out C-sync (checkable under Powerstrip), you don't need to build this circuit.
With all the document handy, the task is not that hard. The hard part is soldering and configure powerstrip. With RealVNC/WinVNC, the tash is much easier.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-15-2005, 04:42 PM   #13
MySQL Error
MatrixPC's Avatar
Look thru this thread, there are lots of usefull info I took pictures of the circuit I built and solder point and screen shot of Power strip setting
http://www.mp3car.com/vbulletin/show...ighlight=PSOne
Old 02-15-2005, 10:47 PM   #14
starfox's Avatar
Sure will fix that soon.
Old 02-16-2005, 01:25 PM   #15
MySQL Error
MatrixPC's Avatar
The circuit I draw
Is base on the info on this page. Scroll down to
TTL level sync signal
flip down VGA LCD? SirCyRo LCD/Display 6 09-18-2006 07:14 AM
Cheap working 9.6"Monochrome 640x480 VGA LCD screen & ISA controller card with cables Frank Grayson General Hardware Discussion 14 12-09-2005 04:03 PM
how to check the PSone LCD is ok? okashi LCD/Display 6 07-31-2004 08:05 AM
6.4"-8.4" VGA TFT LCD w/ Touch Screen Lag117 LCD/Display 5 12-15-2002 11:47 PM
FS: 8.4" VGA LCD (DennisK) with touch controller for SBC's Meatballman Classified Archive 18 06-29-2002 02:35 AM
