Old 12-09-2004, 09:59 AM   #1
Lilliput TS issue (possibly different one)
Not sure if any of you have experienced this particular issue, I tried searching to find it but couldn't find one similar. Like a few others, my Lilliput has a minor touch issue. It's super perfect over the entire screen, except the edges. About 1/4" edge around the entire screen is completely off for calibration and touching. In fact, anywhere within that 1/4" band/edge will yield touches being placed sometimes an inch away from my finger, which means I can't calibrate the darn thing. Also makes touching at the edges impossible.
I'm thinking maybe some of the plastic bezel is clamping down on the TS film, but it's just a guess. Don't have the time to play with it right now, but other than that I love it.
Any ideas? I have a need for more of these screens, and just want to make sure the primary one works fine.
Willow is offline   Reply With Quote
Old 12-09-2004, 12:01 PM   #2
digitalww's Avatar
It sounds like a bad touch panel. What does your 25 point calibration look like? Can you post a screen shot? Best bet would be to try and get a replacement from where you bought it.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 12-09-2004, 12:50 PM   #3
willow - my screen reacted the same way until i did a calibration, then it was fine.
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
roleary is offline   Reply With Quote
Old 12-10-2004, 09:37 AM   #4
Armen:
She won't calibrate on 4 or 25-point because the starting point, bottom-left corner, is out of reach of the tap. When I tap, it shows up about a 1/4" to the upper-right away from the darn point. All the other points in the center I can hit fine.
I've been using it in the car all night, and in all actuality it doesn't affect anything except one tiny button in a corner, which I modified and made a bit bigger.
Just an annoying thing..
I'd still buy a Lilly for other things for sure.
Old 12-10-2004, 09:42 AM   #5
Shayughul's Avatar
Armen:
Not sure if you are using the same calibration that I have for my Lilli.....but for mine you have to hold done on the circle until it turns green.....not just tap it as you suggested you might be doing.
Try doing the calibration and holding on the circle until it turns green....no longer flashes. Then move on to the next.
Might help.
Shayughul is offline   Reply With Quote
Old 12-11-2004, 10:10 AM   #6
Hahahaha, I was reading the word "touch" as in a quick touch, not a hold. That fixed it, thanks.
That shows what happens when you work 92 hours a week.
Lilliput touchscreen issue skeeter007 LCD/Display 1 11-22-2004 12:51 AM
Hmm.. possibly killed my lilliput... Magma LCD/Display 10 09-02-2004 04:08 PM
Lilliput Possibly shorted? Dead? savante LCD/Display 13 07-23-2004 05:39 PM
Powering Lilliput Issue Noctris Power Supplies 3 05-21-2004 01:15 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
