12-10-2004, 09:12 AM
#1
Anyone with experience of Liliput 8" VGA TS
Howdy folks,
just wondering if anybody has any experiences to share about the Lilliput 8" VGA Touchscreen...
My 7" Lilli's TS has died and I am sending back for a replacement which has already been agreed with the seller, however, I was wondering whether or not offer her the extra £25 and ask for an 8" in return...
This screen is native 800x600 @4:3 and so would get rid of my quest for 800x480. And also provide a slightly larger viewable area. And the picture would also be a lot clearer wouldn't it when running on native res.
The actual case width is only about 15mm different so it will still fit in my car.
Any advice is welcome, except that telling me to buy a Gain/Xenarc, as she won't refund my money, only exchange screens. And she only deals with Lilliput, or AV-4u as they seem to be badged now...
John
12-10-2004, 09:43 AM
#2
i've never had a problem with mine. i temporarily mount it in my car so maybe every other night i take it off to hide in the trunk so noone steals it. the connections are still fine, etc. i really have not had any problems with it at all.
rebuilding carpc... kinda..
12-14-2004, 03:49 AM
#3
So is the Touchscreen problem only an issue with the 7" screen???
John
12-15-2004, 07:08 PM
#4
Are you sure the native resolution is 800*600? When I asked the Lilliput-seller at Ebay what the native resolution was, they responded 640*480. Is there two diffrent Lilliput 8" TS out there? I have read something about two different versions and one of them had a cheaper 640*480 Sharp LCD. Maybe you should stay away from this screen?
12-16-2004, 01:41 PM
#5
My 8" lilliput native resolution is 800x600. there is even a little sticker on the back that says something like for best picture run at 800x600
My touchscreen did go on my 8" lilliput after 3-4 days of using it, contacted Armen and he sent me a new screen. So far no problems with the new unit after 2 days of using it. It's kinda funny since Armen listed a 8" lilliput with no touchscreen for sale, that might be my old one!
Anyways my problem might be rare, I haven’t heard about any problems with 8" lilliputs. Oh and BTW: on my 7" lilliput I have never had a problem with the touchscreen and I have had it for about a year or so.
12-18-2004, 10:55 AM
#6
Will this low res 8" lilli be a bad choise?
Solar TPanel8
(Lilliput 809GL-80NP XGA)
Key Specifications &
Special Features:
Screen size: 8 inches digital
Touch Screen
On Screen Display Control
Full function infrared remote control
For PC, Server, GPS, and various VGA Use
Compatible with DVB/SDVD/DVD/VCD and security camera display
VGA input (15 pin D-SUB) S-video input optional
Audio Input Speaker built-in
PAL/NTSC multi-system
2 video inputs
High resolution display - up to 1024x768 (HxV) formatted
Specifications: Screen Size: 20.3cm (Diagonal 8")
4:3 Aspect Ratio
Supported Resolution: 1024 x 768 (HxV)
Dot Resolution: 640(H) x RGB x 480(V) dots (1 pixel= R+G+B dots)
Pixel Pitch: 0.2535(H) x 0.2535(V) mm
Active Area: 162.2x 121.7mm
Number of Colors: 262,144
LCD Brightness (w/o Touchscreen)*: 400 cd/m2 Display Brightness
(w/ Touchscreen): 280 cd/m2
Response Time: 30 Ms
Contrast: 200:1 Viewing Angle: 65/65(R/L), 45/60(U/D)
Degrees Back-Light: Side Light System
CFL 1 Tube LCD Mode: Normally white/Twisted Nematic
Touch Screen Interface: USB port Operating
Voltage: DC 11-13V
Power Consumption: <9W Operating
Temperature: 20-110
Dimension (mm): 205W x 163H x 40D 8x6.4x1.6
Weight (kg): 0.85
12-18-2004, 05:10 PM
#7
Can enyone offer any suggestions to why I cant get my 8" Lilliput TS to work on my Laptop...
The units works no problems on my desktop, I get the following problems when loading up the software...
Laptop - toshiba 4600
op sys - windows XP pro (still on SP1)
Problems:
Error message, "Unable to remove support files, RPC server unobtainable" this error message comes up half way thru installation, its searching for com ports. It seaches thru some com ports then the install is stopped, no programs are loaded in the start menu (They are loaded into the correct file location)
Then when I open up the touchkit.exe file it shows not controller and also have no monitor.
The USB devise driver loads up ok, just cant get the touch screen part working....
Can anyone lend me some knowledge that will fix this problem...
12-18-2004, 10:38 PM
#8
Sorry to bother everyone again on this subject, but i found out why it wasnt working (By accident mind you)
it was the last thing i could try and was turn the RPC service from network service to local service and it all came good...
works like a brought one...
cheers
Merv
Darwin, Aus
Sorry to bother everyone..
12-26-2004, 09:18 AM
#9
How is the brightness compare to a 7" Lilliput? Anyone have experiences with both?
How do these compare to the Xenarc 8"?
Installation Complete, pics soon
EPIA M10000 in Morex 3688 case
FrodoPlayer
CoPilot Live 8
Back from long hiatus, will be rebuilding soon
03-08-2006, 04:10 PM
#10
Ugg RPC Server unavaiable
Xenarc 700TSV
Aopen Pandora 915.
"The RPS Server is Unavailable" has got me.
How does that switch to local go ?
Aopen Pandora Mini PC, Xenarc700, Windows Media Center Edition Project going into 89 Volkswagen Vanagon.
| Thread Tools |
| Display Modes |
Linear Mode
