Old 12-21-2004, 06:47 PM   #1
Camryputer's Avatar
LCD Low Temperature Performance
It was very cold this week in Michigan: 4 degrees F (-15C). I was pleasantly surprised that my Xenarc looked fine when I booted my system early in the AM. It was dark so I didn't mind that the brightness was degraded. Other than that, the contrast was nice and the response time didn't seem to be a problem. Very impressive.
Please post your cold weather experience...
2002 Camry SE: M6K, Xenarc, Earthmate GPS/St.Atlas'07
PW70A card supply, 802.11b,
Andrea Dual Mic Array/DSP Noise filtering for VR.
Camryputer is offline   Reply With Quote
Old 12-22-2004, 07:01 AM   #2
wi77iam's Avatar
After that cold snap here in Philly, my Xenarc crapped out and hasn't powered on since. I'm hoping this is only a temporary thing. Last winter, the same thing would happen, but after driving for awhile and warming up, it would power itself up.
wi77iam is offline   Reply With Quote
Old 12-22-2004, 07:06 AM   #3
dingofarmer's Avatar
Colorado,
My lili, is a tad bit dim for a few minutes, and the ts is a bit slow, but overall works great, about 20F outside right now.
dingofarmer is offline   Reply With Quote
Old 12-22-2004, 09:56 PM   #4
NY here No where near 5Deg F, but for the couple of days it went below 32, starts up being dimmer then normal but operations were fine. Once warmed up all looked normal and as brite as it normally is.
DaRacerz is offline   Reply With Quote
Old 12-22-2004, 10:23 PM   #5
chuckctv's Avatar
i placed all power transformers and heat/power equipment just behind the screen to help warm up faster and it works great....
chuck
www.XionElectronics.com
**MY NEW STORE** Come Visit
chuckctv is offline   Reply With Quote
Old 12-23-2004, 10:45 AM   #6
my computer would boot but the HD wouldn't spin up... the screen is extremely dark compared to normal, but works 100% once I reach a warmer temp... today it was 6 deg F and snowing, car parked outside (under cover) but snowing... about 10 minutes of engine warmup and heat on full blast and it was okay...
mgithens is offline   Reply With Quote
Old 12-23-2004, 03:36 PM   #7
mauri's Avatar
Italy today
-6 degre C ,about fiwe hours external in the parking my car,the Lilli 7" TS its only dark......
The Epia carpc work fine, only the lilli not work.
Power ok , but black image....
Tomorrow i see if the Lilli work ok or its dead!
Mauri
mauri is offline   Reply With Quote
Old 12-23-2004, 08:17 PM   #8
choyak's Avatar
This makes me ultra happy that I live in California now. My original home of Wisconsin would have this also!!
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
choyak is offline   Reply With Quote
Old 12-24-2004, 05:03 PM   #9
mauri's Avatar
Yes ,
the cold tamper whit the lilliput they don't do work.
Today I have tried after having heated and returned everything ok.
Mauri
Old 12-24-2004, 07:31 PM   #10
IntellaWorks's Avatar
Everyone should post thier hardware, as well here....
Xenarc 7" - mounted in dash
MII10000, Toshiba 20GB 2.5" drive, ITPS startup
then write the temps and problems you had (if any)
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
6.4"-8.4" VGA TFT LCD w/ Touch Screen Lag117 LCD/Display 5 12-15-2002 11:47 PM
lcd datasheet help oddcomp LCD/Display 1 11-08-2002 11:24 AM
FS: 15.4" TFT LCD w/ analog RGB input, 200nits, 1280x1024x16million, 12v DC input Mad Jad Classified Archive 5 08-20-2002 09:32 PM
LCD picture quality not good. Will shielding help? pigseye General Hardware Discussion 2 12-27-2001 10:51 AM
