Old 12-23-2004, 01:56 PM   #1
Lord_Pall is on a distinguished road
Blurry Xenarc Problem
So i've read up on this and I'm wondering if this is a solveable problem.
Xenarc 7" touchscreen
MII1200000 with stock video, i think the most current drivers.
So i'm stuck running 800X600@75hz.
it doesn't look bad.. But when i put on an extension cord (any vga extension, i even tried a hommeade one, all lengths), The picture gets blurrier. It's still usable, but fairly noticable.
Anyone seen this or have any idea if it's solveable?
Lord_Pall is offline   Reply With Quote
Old 12-23-2004, 02:53 PM   #2
Zip-Lock is on a distinguished road
Did you run the auto adjust feature on the LCD?
Zip-Lock is offline   Reply With Quote
Old 12-23-2004, 03:07 PM   #3
Yup.. repeatedly..
Old 12-23-2004, 03:28 PM   #4
Nutz is on a distinguished road
I would try a high quality monitor extension cable. Most likely you are trying a thin cable with poor insulation.
Nutz is offline   Reply With Quote
Old 12-24-2004, 10:31 AM   #5
Any recommendations? Preferably with a store?
Old 12-24-2004, 05:38 PM   #6
The one i'm using is from Radio Shack, but they are expensive. Just go into any computer store and you should be able to tell how good they are insulated by their thickness.
Old 12-24-2004, 06:47 PM   #7
Look at the official Xenarc extension cable. http://www.mp3car.com/store/product_...products_id=64
Old 12-24-2004, 07:27 PM   #8
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
If you notice, VGA only has 15 pins yet the cord is very thick. The reason for this is because of all the shilding around each wire. The farther you go the more the signals are mixed and the final product (at the monitor) becomes more blurry.
Buying a higher end VGA cable is probably the best way to go.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 12-24-2004, 07:48 PM   #9
I'll give it a shot.. I tested with a custom made shielded cat6 cable similiar to the ones I use for my Home theater setup.. They're good for extremely long runs (35 feet is what i'm using).
I made a 5 footer, and it was blurry..
I'll try a high end store bought one..
Old 12-24-2004, 09:26 PM   #10
muldrick's Avatar
muldrick is on a distinguished road
Right...http://www.mp3car.com/store/product...?products_id=64
That's were I just got mine
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Problem with Xenarc TS bluehcc LCD/Display 1 01-19-2005 01:13 AM
Xenarc 700YV Problem Sivion LCD/Display 0 12-04-2004 06:46 PM
Xenarc TS USB wire harness mod doc LCD/Display 2 03-23-2004 04:17 AM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
Xenarc 7" Touchscreen VGA Group Buy. Skippman LCD/Display 144 07-27-2002 11:52 AM
