Old 12-27-2004, 01:09 PM   #1
stric is on a distinguished road
Linitx or MM400 touchscreen error??
Hi, I have Cartft MM400 touchscreen and when I want to instal touchscreen drivers I get the following error during reading com ports :
Error Number:0x80040707
Description: Dll function call crashed: ISRT.CallDLLFn
Setup will now terminate
Does anyone know what to do?
stric is offline   Reply With Quote
Old 03-04-2007, 02:35 PM   #2
atlttz's Avatar
atlttz is an unknown quantity at this point
Did you find the answer?
Did you ever get an answer to this question? I am having the same problem and can not find the answer. I have found in some other places that installing the sofware before hooking up the TFT works(did not for me) or you can try installing in safe mode(again did not work for me). Anyhow, let me know if this helps, or if you have a solution that may work. Thanks
atlttz is offline   Reply With Quote
Old 03-04-2007, 03:25 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You just resurrected a thread that's over to years old.
While that's not a bad thing, you're probably not going to get an answer from the OP...
That said...
Do you have the latest egalax drivers installed, or just the ones that came on the CD with the unit?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-04-2007, 03:37 PM   #4
atlttz's Avatar
Thanks for replying though. I see where there is a lot of aggrevation when people do not research and just post a new thread. I replied to this to avoid doing just that. I only have the ones that were included on the disk. It is made by delong and is model dlo7oih. Everything I have found regarding the drivers is in another language. Do the egalax drivers go in conjuntion w/the drivers on the cd, or instead of. I am going to search for them and will repost any questions. Thanks again!
Old 03-04-2007, 03:41 PM   #5
Instead of the drivers. It's just a newer version of the same driver.
Download them here: http://www.eeti.com.tw/web20/eg/drivers.htm
Old 03-04-2007, 03:47 PM   #6
atlttz's Avatar
Any suggestions on the sequence I should use, i.e. install and then plug in the TFT or was that more urban legend? Thanks for the link. I will let you know how it all works out.
Old 03-04-2007, 03:50 PM   #7
Disconnect the screen.
Uninstall the old drivers.
Reboot.
Install new drivers.
Connect touchscreen.
Old 03-04-2007, 04:40 PM   #8
In my case I think it was drivers problem. I was trying the one from CD, but than I used the one from web (www.cartft.com) and it works.
Old 03-04-2007, 06:26 PM   #9
atlttz's Avatar
I am using a dell laptop to hook everything to. could there be an issue with the cpu "seeing" 2 mice,i.e. the touchpad and the touchscreen. The touch screen responds when I touch it, but only moves the cursor. When I remove my finger , the mouse goes to bottom right and constantly right clicks with the new drivers you showed me.. Will not let me calibrate. Any ideas?
LinITX 7" Widescreen Touchscreen Monitor Review Confused LCD/Display 165 06-19-2006 12:40 AM
LinITX 7" touchscreen displays whoracle LCD/Display 13 11-20-2004 01:50 AM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 10:47 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
Error #91 SiGmA_X ME Archive 18 01-08-2004 10:40 PM
