Simple Wiring Question
I have two 7" monitors, non-VGA that I need to power. They each want 12v / 1.2A. I want to wire them directly into a cigarette lighter socket so it will feed both.
Should I put a fuse on the line? I'm assuming so, and if so is it best before or after the split to the monitors, fuse them as one or individually? And well, what size fuses to use, a little higher than load? 1.5A if two, 3A if only one?
Chris.
*not an electicial expert*
