Old 12-29-2004, 09:19 PM   #1
Giuliano is on a distinguished road
8.4" LCD in WRX dash.
I've been thinking for a long time about what kind of LCD I wanted to put in my WRX's dash.
I wanted a LCD that used LVDS so I could hook it up directly to the motherboard.. and not have to use a controller board to hook it up via a VGA port.
An 8" widescreen LCD would fit the double-din opening perfectly, except that they're hard as hell to obtain in single-quantities, basically making them unavailable.
A 7" widescreen LCD would be slightly smaller, and is easily available, but not in LVDS.. and the 800x480 problem is one I'd rather avoid.
An 8.4" 4:3 LCD would fit the double-din width perfectly, but is about 2cm too tall.
So instead, I've been looking at an 8.4" 4:3 800x600 LVDS LCD panel from a local supplier, shown and listed here:
http://www.evisiondisplays.com/images/ub084s01.jpg
http://www.evisiondisplays.com/evd084s01-1.html
Panel layout w/touchscreen:
http://www.evisiondisplays.com/evd084s01-1_M.html
I created a mockup LCD panel out of foamboard that's exactly the size of the actual LCD panel, and decided the panel will fit, although I'll have to do some cutting.
Pictures attached:
lcd template.jpg shows the foamboard mockup, with lines drawn on it to show where the actual display area would be.
mockup1 and mockup2 show the foamboard LCD taped to the radio bezel - you can see the drawn lines match up with the width of the bezel opening.
mockup3 and mockup4 show the LCD and bezel in place on the dash.
You can see that the LCD will fit.. but I'd have to lose the cup holder in the upper right, cut away the plastic in the upper left, and reshape the bezel entirely.
I can live without the cup holder, and those plastic parts are replaceable, so cutting it up wouldn't really be a problem for me.
I'm thinking that the computer itself would go above the vents, in one of those gauge pod housings, so the LCD would be close enough to the motherboard for LVDS to work (~12").
Edit: Cross-referencing a post of mine from ~9 months ago, with part numbers and prices:
http://www.mp3car.com/vbulletin/lcd-display/23765-possible-8-4-lvds-1024x768-lcd.html#post179720
Thoughts?
Giuliano is offline   Reply With Quote
Old 12-30-2004, 04:50 PM   #2
I've further decided that instead of cutting apart the original dash bezel parts, I'm going to cast duplicates out of polyurethane resin (plastic), using silicone rubber molding materials instead, and modify the duplicates.
The parts that I would have had to cut are:
66065E $52.26 Panel-audio (radio bezel)
66065O $70.50 Panel-center (center heat/ac vents w/hazard switch)
66080 $33.62 Console-instrument panel (the lower center console itself)
The parts are listed here, and are shown in the 2nd and 3rd diagrams:
http://www.subaruparts.com/diag/?mod...category=660-1
Rather than modify/destroy $120-150 worth of parts, I'm going to make exact duplicates and modify those instead..
I'll be cross-posting a thread in Fabrication with pictures tomorrow, I have to pick up the casting materials tomorrow morning.
The upshot of this is, if anybody else wants to put a 8.4" LCD in their 2002-2004(maybe) Impreza/WRX, I'll be able to cast a perfect part easily.
Old 12-30-2004, 10:47 PM   #3
Fabrication Thread
Fabrication thread posted here:
http://www.mp3car.com/vbulletin/fabrication/39205-how-duplicating-radio-bezel.html
If anybody can tell me how to embed those attached images inline, I would appreciate it.. PM is fine.
Old 12-31-2004, 11:30 AM   #4
ncamara's Avatar
ncamara is on a distinguished road
What's the price for this screen? Do you plan on plugging this into your MII board with LVDS?
Installation Complete, pics soon
EPIA M10000 in Morex 3688 case
FrodoPlayer
CoPilot Live 8
Back from long hiatus, will be rebuilding soon
ncamara is offline   Reply With Quote
Old 12-31-2004, 11:41 AM   #5
The price for this screen itself was $428 when I got the quote 9 months ago, so it might have changed since then.
The price was for the LVDS LCD panel itself, a brightness enhancement, and a touch screen panel.
That cost does not include the inverter ($25), the touch-screen controller ($25), or the various cables necessary.
The total cost was $511, not including shipping or tax.
See this post for the part numbers and details:
http://www.mp3car.com/vbulletin/showthread.php?p=179720
And while I will be plugging it into an LVDS-enabled motherboard, it probably won't be a MII..
I'm currently considering this board from Commell Systems:
http://www.commell-sys.com/Product/SBC/LV-671.HTM
The Taiwan site has more info/documents:
http://www.commell.com.tw/Product/SBC/LV-671.HTM
The board goes for about $395 without a processor, such as from here:
http://www.bwi.com/scripts/site/site...tion/configure
The board has the useful options of a MiniPCI slot or a MiniAGP slot, either of which can be used for interesting possibilities.
Old 12-31-2004, 12:40 PM   #6
ncamara's Avatar
Wow. Quite expensive to get this entire working system.
FrodoPlayer
CoPilot Live 8
Old 12-31-2004, 01:42 PM   #7
Oh yes, perfection doesn't come cheap!
But for the price, I'll get an 8.4" LCD, with a native resolution of 800x600, a standard aspect ratio of 4:3, and a direct digital LVDS connection to the motherboard, freeing up the analog VGA port for a secondary larger display elsewhere in the car.. such as in the back seat.
And for a comparison, here's Mp3Car.com's own Xenarc 800TSV:
http://www.mp3car.com/store/product_...products_id=55
The price is about the same ($485 vs $511), but you're only getting a physical resolution of 640x480...
And for LCD's, there is no other resolution other than the panel's native physical resolution - sure, you can do scaling (1024x768 -> 800x600), but it isn't going to look good.
Old 12-31-2004, 02:09 PM   #8
Mockup LCD in dash..
And for those of you who want more, here's a picture of how the LCD (posterboard mockup) would look in the WRX's dash.
The drawn lines on the posterboard represent the viewable area of the 8.4" LCD.
The posterboard is off-center on purpose, as the viewable area of the LCD is also off-center.
As you can see in mockup5, it looks like the LCD will fit.
Mockup6 shows the panel with the A/C bezel in place - you can see I'm going to have to cut off that bottom section of the A/C bezel to make it fit, and I'm going to lose the space where the cup holder was.
Big, isn't it?
Old 12-31-2004, 09:18 PM   #9
ncamara's Avatar
I think the Xenarc 8" native resolution is 800x600. I know the website says 640x480 but the back of the screen says 800x600. Maybe I'm confused with the Lilliput 8"; if anyone has it and I'm wrong, please correct me.
FrodoPlayer
CoPilot Live 8
Old 12-31-2004, 09:40 PM   #10
I would kind of doubt that it's physical resolution is 800x600 - the specs do say the physical resolution is 640x480, and the dot resolution is 1920 x 480.
A dot resolution of 1920 x 480 really is 640 x 3 RGB x 480, so it matches the physical resolution of 640x480.
The 800x600 shown on the back of the screen is likely the resolution that the VGA video controller on the panel can accept, and it simply scales the picture down to fit the smaller resolution, losing detail in the process.
Of course, if anybody has one taken apart and can get the make and model number of the LCD panel itself, I'm sure I could find the spec sheet.
Old 12-31-2004, 11:17 PM   #11
One more bit of detail:
The LCD panel listed above is actually based on the AU Optronics LCD model B084SN01, with brightness enhancements making it about 300 nits with the touchscreen.
Here's a spec sheet for the LCD itself:
http://www.qscomp.cz/Pdf/B084SN01.pdf
I'm taking some better measurements for my LCD panel "blank" from the dimensions on this spec sheet, as the numbers are much clearer in the PDF version.
Old 01-01-2005, 01:10 AM   #12
Measured out the mounting points..
With the dimensions in the spec sheet PDF, I've accurately laid out the locations of the LCD mounting points on my posterboard blank, and test-fitted it for size in the dash.
Image Linky..
The picture shows the four mount points in red, and a blue and a green line.
The Blue line represents the thin plastic stabilizer support bar that's part of the lower center console - this part may need to be cut away for the LCD to fit, but as it's not a critical part, it might be fine.
A replacement lower center console is $30, so it isn't a big loss if it needs to be replaced.
The Green line represents the sturdy upper support bar that is part of the upper dash, and you do not want to have to cut this out, as you would have to replace the entire top dashboard.
Thankfully, this upper support bar will also provide an easy way to secure the upper part of the LCD, by making a piece to fit the support bar exactly.
The result should be a mounting system that sits in place securely without having to screw it to the dash's plastic.
This post in my Fabrication thread shows the rubber blank I made for the right-side mounting block, which will be extended down to support the lower right mounting point:
http://www.mp3car.com/vbulletin/show...3&postcount=17
Old 01-01-2005, 04:44 PM   #13
8.4" 1024x768 !!!
Okay, I just about went into hysterical fits of glee when I saw this...
Optrex America makes an 8.4" LVDS 18-bit LCD panel that has a native resolution of 1024x768!
Check it out:
http://www.optrex.com/Products/PartD...%2DFW%2DA%2DAA
I can buy one of these RIGHT NOW from Mouser Electronics for $491:
http://www.mouser.com/index.cfm?hand..._pcodeid=80500
The $491 price is for the LCD panel itself, and I do not believe it comes with a touch screen panel for that price... but those are easy enough to find for this size, as 8.4" is fairly common.
Edit: Fujitsu 8.4" touch panel is $42.50, and is 1.4mm thick:
http://www.mouser.com/index.cfm?hand...oductid=587403
And the best part?
The size and layout is almost exactly the same as the 800x600 LCD I was looking at, but maybe a few mm thicker.. I should still be able to fit it.
Total thickness w/ LCD (~11mm), touch panel (~2mm), and 1mm foam tape.. 14mm.. 15mm for good rounding up.
I think I've found my new favorite LCD..
Old 01-01-2005, 05:16 PM   #14
Upper Left mounting post.
Here's pics of the rubber blank I made for the upper-left mounting post, which fits snugly in the dash plastic without the need for screws to hold it in place.
Old 01-02-2005, 03:19 AM   #15
Optrex LCD won't fit..
Well, I took the dimensions of that new Optrex 8.4" LCD, and turns out that it's the right width, but it's too tall - it won't fit.
I made a few cuts inside the dash, as shown in the first pic - I removed the horizontal connector that joined the left and right sides of the lower center console.
I cut a posterboard blank for the Optrex 8.4" LCD, and as you can see from the second picture, there's no way it will fit.. not unless I get rid of the A/C controls.. and replace them with servo controls... but that's a project for later.
The last picture shows the original LCD blank in place, and it fits perfectly.
Maybe I can upgrade to the Optrex LCD down the road, after I've built that servo-controlled A/C system to replace the manual controls I would have ditched to fit the larger LCD...
Accord lcd question - placing lcd deeper in dash mykolJay Fabrication 9 09-29-2004 02:02 PM
Where would you put an LCD in this dash? redbeamer Fabrication 11 08-10-2004 02:03 PM
In dash lcd skoda LCD/Display 2 12-22-2002 02:12 PM
Anyone want a Clarion 5.6" In Dash LCD? gguy LCD/Display 2 05-30-2001 11:29 PM
in dash LCD question,. moahdib LCD/Display 10 05-25-2001 10:35 PM
