Old 01-08-2005, 08:36 PM   #1
Raw Wave
edrex's Avatar
Question Mounting the Xenarc in the dash
Ok, got my Xenarc now. () Now I need to know how to mount it in the dash. A search turned up mostly people who were mounting on the dash in different areas. I have a double din factory headunit and want to put the Xenarc in its place. How does the unit stay in place? Will I need extra brackets for mounting it? Are there any write-ups on how to do it?
Thanks for the help.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Advertisement Sponsored links
Old 01-08-2005, 08:58 PM   #2
Talk to Altimat. I know his car is a different year, but he should have some good ideas... or do a search for your car. I've seen the Altima dash around here with an LCD in it somewhere around here, so somebody has definitely done it before.
I've taken apart my Maxima dash a million times already, and I can tell you that there's a LOT of stuff back there where you can mount the screen -- at least in my car. I think most people just fabricate the front of the bezel into the dash, then screw the back into the front and call it a day.
viguera is offline   Reply With Quote
Old 01-09-2005, 12:55 AM   #3
alti's Avatar
there are Three altima instals that I am aware of in 3ed gen altimas
Altimat an one of the others installed theres above the radio where you have a cubby i think (mine has the vents there, in 05 they moved the vents to the side of the radio.
There was another that installed a 6.5 screen (i think) from EarthLCD where the radio is (was)
Mine when done will also be where the radio is but is a larger 10.4"
go to the advanced search feature and search the show off your project forum for altima they should all come up. some of the pics no longer work but pm altimat he could likely send you his and the other above the radio install was also done by him.
hope this helps
good luck!
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
new ssr, xenarc in dash or pull-out? pesos LCD/Display 5 01-09-2005 02:40 PM
Mounting Xenarc inside dash - But removable! Pabs LCD/Display 11 09-06-2004 04:20 PM
Mounting ideas for slimline dvd player in dash psyclobe General Hardware Discussion 19 02-11-2004 11:52 AM
Mounting the LCD inside the dash? XxAndyxX Newbie 9 01-16-2004 04:51 PM
dash mounting smashr2k LCD/Display 2 10-23-2002 12:27 AM
