Old 01-10-2005, 01:24 AM   #1
Powering LCD through XBOX and PC
I have a clarion lcd and have a lot of noise on it. Figure it might help to power it off the power supply wires of the pc. only problem is that i also have an xbox and with it only hooked up to the pc, the pc would always have to be on, even if i want to only use the xbox. Normally that is fine, but with winter temps in canada, the battery normally cannot produce enough power for both. My question is if it possible to splice into both power supplies for power so i can get power from either source. will it over-power the lcd if both the xbox and pc are on at the same time?
mazda3uzr is offline   Reply With Quote
Old 01-10-2005, 01:50 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
That's not a good idea.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
modified xbox instead of a PC? hydraulix General MP3Car Discussion 80 12-05-2005 01:14 PM
Linux Build or Xbox Port??? boschk2002 FrodoPlayer 5 01-09-2005 02:43 PM
Pc into the xbox case. kickercivic1 General Hardware Discussion 8 12-23-2004 04:07 PM
OPUS powering xbox and Shuttle? Bitflip Power Supplies 2 04-25-2004 09:43 AM
Few questions about my current setup (xbox modded) migrate to PC... Urinemachine General Hardware Discussion 0 11-13-2003 06:24 PM
