Old 01-15-2005, 08:49 PM   #16
Rover_Eli's Avatar
Here's the pics you requested as well...
Rover_Eli is offline   Reply With Quote
Old 01-15-2005, 08:51 PM   #17
Rover_Eli's Avatar
Also...
Can you post a better pic of what the white and black wires are? Are they just RCA inputs?
Old 01-15-2005, 08:52 PM   #18
My man uses Levitra.
Peoples's Avatar
i'd get them out of a car your friend was selling
Not sure, i'd just try soldering to the pins, and making your own connectors. Cur the plastic around the pins, and just tin the edges, wouldnt be a hard soldering job.
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 01-15-2005, 08:53 PM   #19
Peoples's Avatar
my camera is ****. But yeah the white and black wires are just RCA.
PC Components:
My work log
Old 01-15-2005, 09:56 PM   #20
MySQL Error
jcdillin's Avatar
If you check each pin, and find the one that goes to the black side of that cap thats Labeled 2CS 100 16V that will be your ground and the one next to it should be 12v then all you have to do is attach the other two wires for video
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 01-15-2005, 10:14 PM   #21
Para Laura
thanatos106's Avatar
Quote: Originally Posted by Rover_Eli
So where can I get two connectors like those?
Get the conectors from an old pc look for the ones that got to internal speaker(this one have four pins) and also try to use the pins as well(use you soldering tolls for this).
thanatos106 is offline   Reply With Quote
Old 01-15-2005, 10:19 PM   #22
Para Laura
Also check if the tracks goes to the power area(the one that have a lot of power transistor,condensors and resistors)
Check continuity for the conector to diferent parts of the board.
Old 01-15-2005, 10:21 PM   #23
cbergeron's Avatar
Heh - unless you have some big quid, you're SOL. They are proprietary connectors from overseas (Taiwan, I think). They're only sold in large quantity (1000 lots, etc). You might be able to get free samples, but the mfr. is in Taiwan and their website isn't in English.
Let me know if you find a source, because I've been looking for them as well...
DashPC - The Linux Car (since 1999).
Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
As seen in the book Geek My Ride
cbergeron is offline   Reply With Quote
Old 01-15-2005, 10:26 PM   #24
Rover_Eli's Avatar
Thanks guys...one more question though - why would there be two RCA's? Two separate video inputs?
There are two switches that you can kind of see in one of those pics, one says "TURN LR/UD" which obviously turns the signal for up/down or left/right viewing, and the other says "S/D OFF/ON" which I am not sure of...
Old 01-16-2005, 03:00 AM   #25
strohmrs's Avatar
Two RCA's? The two video lines are for VIDEO and VIDEO GND...to one RCA.
Can't help with the switch labels.
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
strohmrs is offline   Reply With Quote
Old 01-16-2005, 03:39 AM   #26
strohmrs's Avatar
Removing the tape or whatever that is from the bottom of the board before taking a picture of it would have been a BIG help.
From what I can see, the two center pins are connected to the ground plane on the bottom of the board. Those are your ground points for your power and outer conductor for your RCA jack for your video ground. Doesn't matter which of the two center pins goes to each of them because they are both grounded.
For the other two pins, the one furthest from the corner of the board has a thick trace going to a power filter cap on the top of the board. That is your 12V input. That leaves the pin closest to the corner of the board, with the small trace, your video input which you need to connect to the center conductor of the RCA jack.
Rick S.
Old 01-16-2005, 09:31 AM   #27
Rover_Eli's Avatar
As good as I could do...
Here's the best I could do with removing all that old tape off the backside.
Old 01-16-2005, 09:57 AM   #28
Rover_Eli's Avatar
Also, is this what you mean by separating the outside and center conductors for the RCA cable? Would I run this straight to the board on those two pins on the right?
Old 01-16-2005, 10:00 AM   #29
MySQL Error
jcdillin's Avatar
yeah you got it, now the red is going to go to the pin closest to the edge of the board and the gold unshielded is going to go to one of the middle pins.
肚子笑痛了
S60 Install
Old 01-16-2005, 10:13 AM   #30
strohmrs's Avatar
Yes. Just wire that up as I indicated on the picture in my previous post. Hope it looks good!
Rick S.
Has anybody ever got lil/Xen screen to clock onto native res? ChrisC LCD/Display 5 04-30-2004 12:25 PM
What the....same screen? Good screen? Seabass General Hardware Discussion 4 03-31-2004 12:37 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
NEC Versa M/75 Laptop TFT screen w/touch Macgyver777 LCD/Display 23 03-24-2002 03:14 AM
Laptop/LCD screen hookup... UrbanTacticz LCD/Display 1 11-28-2001 06:49 PM
