Old 02-04-2005, 11:11 AM   #1
garo's Avatar
garo is on a distinguished road
Poor Quality on Xenarc 700TR
Hi!
I bought a Xenarc 700TR. If I use the cable given in bundle (2mt, non-shielded) I get a perfect image. But, if I use a very good 3mt long shieled vga cable, I get a bad quality image (blurred). I tried other cables and I always get the same result.
I don't know what to do! Please help me!!!
Tnx! Garo
garo is offline   Reply With Quote
Old 02-08-2005, 02:29 PM   #2
garo's Avatar
Please somebody help me!!!
No idea?..
Old 02-08-2005, 02:44 PM   #3
yalborap is on a distinguished road
uh....
use the cable you got?
as for why, maybe it's because of how long the cable is.
softmodded xbox, PSOne screen, inverter. simple and effective. Combine with PDA and head unit with aux input, and we're having a wonderful time.
yalborap is offline   Reply With Quote
Old 02-08-2005, 03:00 PM   #4
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
The mp3car store sells a longer version of the Xenarc cable. You might give that one a try...
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 02-08-2005, 03:56 PM   #5
garo's Avatar
Unfortunately that cable is different from mine! I have 700TR that use a slightly different cable... However, a normal vga cable seems to fit well, but I got blurry image
I need a longer cable because I don't have room near the dash to install my pc, so I have to put it in the luggage van.
Old 02-08-2005, 05:11 PM   #6
electronik is on a distinguished road
I have the same problem this time with a LinITX screen. This is what I get:
5m lead laptop to LinITX Screen - Bad dobule ghost to right, like the image is 3 layers thick, with each layer fainter.
5m lead laptop to 17" LCD - sharp
5m Lead tower to 17" LCD - sharp
5m Lead tower to LinITX screen - Bad dobule ghost to right, like the image is 3 layers thick, with each layer fainter.
2m ITX lead to LinITX screen - sharp, no ghosting
2m ITX lead to 17" LCD - sharp, tiny ghosting to the left.
1.5m Iiyama cable to 17" monitor - sharp
1.5m Iiyama cable to LinITX screen - sharp
Which makes me think it's some kind os compatability thing or something? The big 5m cable is a really good quality one with big chokes at either end. I was wondering if the chokes were messing it up or what? It's a total pain in the *** though. Maybe I could cut the chokes off the cable? Or cut the cable and resolder? (the ends are metal, I can open them up, they look OK to resolder, not easy - but possible.)
Must be loads of people runniong these screens with extentions, any advice? Anyone got long cables that work?
Last edited by electronik; 02-08-2005 at 05:53 PM. Reason: wrong 4th result changed
electronik is offline   Reply With Quote
Old 02-08-2005, 05:44 PM   #7
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I'm running my Xenarc 8" TS with a 6 foot extension cable on it. I bought the cheapest one they had and it looks sharp. I'll count myself lucky.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-08-2005, 05:47 PM   #8
Hmm this is interesting. check http://www.mp3car.com/vbulletin/show...host+extension that thread as well.
Looks like we have to get the cheapest cable to make these screens work... the expensive fat ones (mine is triple coax + 7 signal + 2 chokes) mess up the signal for these wee screens!??
Weird, I don't suppose anyone has an explanation?
This should be in big letters in the FAQ if it is true.
Old 02-08-2005, 08:15 PM   #9
garo's Avatar
It seems to be exactly the same problem... We have to find a solution
Old 02-08-2005, 08:19 PM   #10
garo's Avatar
My cable is an high quality cable with two chokes too... The only strange thing I noticed is that the original unshielded Xenarc cable has exactly 15 pins, while the one I use (and almost all the cable that I found in the shops) has 14 pins. Maybe that is the reason? Can someone with "working cables" or extensions look at the number of the pins?
Old 02-08-2005, 08:40 PM   #11
PatO's Avatar
PatO is on a distinguished road
This cable worked with my Xenarc 700TSV:
http://www.newegg.com/app/viewProduc...105-807&depa=0
I have a very small amount of moving static, but it's only visible if you stare at the display from a distance of 6". The static may be from nearby power cables, though.
http://www.jeepmp3.com/
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 02-08-2005, 08:58 PM   #12
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
3m long cable or 9ft ??? Of course your signal will be blurry... look at a 6 ft. VGA cable, ever notice how thick it is ? The reason for that is because it is heavily sheilded the longer the VGA cable you get the worse the quality will be because the signals begin to cross over each other....
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-08-2005, 09:12 PM   #13
-zip-'s Avatar
-zip- is on a distinguished road
My VGA cable is 20 ft long with no troubles at all. I have a lilliput screen but dont think that makes a diff?
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 02-08-2005, 09:13 PM   #14
IntellaWorks - go read again - my 5m cable works fine tower -> desk VGA, but ghosts going tower -> touchscreen! The odd man out is not the cable!
You can buy 25m vga cables... surely they can work somehow without being unreadable??
Surely a lot of people run extensions from their boot to the console?
To me, it points to the screens are set up to work with cheap thin unchoked cable, and that the good stuff messes them up??!??!
FS: EBAY: Xenarc 700TR VGA FlipDown neutral Classified Archive 0 01-16-2005 09:35 AM
Xenarc 700TR: Power digifreak LCD/Display 7 01-08-2005 08:26 AM
Xenarc 700TR - 7" roof-mount VGA w/ TS FiSKARZ LCD/Display 13 11-20-2004 07:52 PM
Xenarc 700TR (flip down LCD with touch screen) Group Buy Zip-Lock Classified Archive 31 10-23-2004 02:04 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
