Old 02-06-2005, 07:41 AM   #1
skitchin is on a distinguished road
Connect PSOne LCD Screen to PC
Hi, new to the forums. I want to hook a PSOne LCD screen to my PC. The problem is I don't know how I should regulate the power to 7.5v. I'm guessing some kind of DC-DC converter that will do 12VDC->7.5VDC. Anyone have suggestions on what part(s) to use or any other solutions. Thanks.
skitchin is offline   Reply With Quote
Old 02-06-2005, 08:54 AM   #2
Osiris's Avatar
Osiris is on a distinguished road
How are you powering your PC? I think that carnetix regulators has an extra plug-in that may do the job for you. Someone verify or correct me on that.
Osiris Networx
--Tuning is all about price vs performance. You've got to find your own medium.--
Osiris is offline   Reply With Quote
Old 02-07-2005, 12:32 AM   #3
Pretend I just had the 5v and 12v source given by the power supply. Simply because I do .
Old 02-07-2005, 09:27 AM   #4
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Go to any game store and pick up one of those cig power adapter for PSOne. Otherwise buy one of those universal/multiple output from wallmart/radiosuck and well game store.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-08-2005, 03:26 PM   #5
ktritz is on a distinguished road
Well, if you could put +12 on the positive and +5 on the negative for 7V...
Dunno if that would actually work.
ktritz is offline   Reply With Quote
Old 02-09-2005, 12:56 PM   #6
mattress is on a distinguished road
+12v for postive and +5v for negative would give you 7v of power, I would assume that would work
(from a standard molex connector in a computer, 12v is yellow, 5v is red)
mattress is offline   Reply With Quote
Old 02-09-2005, 11:58 PM   #7
Tred is on a distinguished road
couldnt u use a resistor? i think its ohms law. volts/amp?
Tred is offline   Reply With Quote
Old 02-10-2005, 10:37 PM   #8
Um, are you sure about the 7v thing? That...doesn't sound like it'd work. Sounds more like it'd short out. I'll try it anyhow because my lcd screen appears to be broken.
Old 02-10-2005, 10:58 PM   #9
Yeh, I didn't do it with the LCD screen, and just as I thought, it created a short(NOTHING FRIED )
Old 02-11-2005, 09:06 AM   #10
how did it create a short? it's not supposed to. the only thing that happens is the voltage drops to 7 volts. that's an easy "fan speed hack" if you want to quiet the fans in your computer down, instead of running at their full 12 volts.
yellow wire is 12v, red wire is 5v (from a molex connector coming from the computers PSU)
you should be able to hook up the 12v where the positive should go to the psone, and then the 5v wire should go to where the negative should go to the psone screen.
no shorts, just the difference in volts. I don't know if this would power the screen, but it does not create a short. you can try googling 7v fan speed hack or something to get more info
Old 02-11-2005, 09:36 AM   #11
Ill1's Avatar
Ill1 is on a distinguished road
The 7 volt thing should work as long as there is no other reference to ground (case, etc.). I would suggest testing on some other non-expensive equipment first, because I have never tried with anything other than a couple of ic chips.
________________
______ILL.1______
Ill1 is offline   Reply With Quote
Old 02-11-2005, 09:45 AM   #12
Nobias's Avatar
Nobias
Get a voltage regulator ic and build a curcuit.
Status: 40%
Car: 2006 Scion tC (Buying)
CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
Screen: Lilliput 7"
Power: Carnetix 1900
GPS: Deluo GPS
Software: nLiteXP, RR, IG, PhoCo
XM: XM Direct
http://www.chrispuckett.com/mp3car/
Nobias is offline   Reply With Quote
Old 02-12-2005, 12:16 PM   #13
xtra is on a distinguished road
you will fry ur lcd when you connect to your computer, because the psone use the same ground.
just buy the offcial car adaptor, i bought mine for $10 in bestbuy
xtra is offline   Reply With Quote
Old 02-13-2005, 11:03 PM   #14
Evil.Commando is on a distinguished road
http://www.eidusa.com/Electronics_Voltage_Regulator.htm
This may help. Built one my self. except for 5v. you dont need the extra caps just the actual IC the caps are for power smoothing.
Evil.Commando is offline   Reply With Quote
Old 02-14-2005, 01:37 PM   #15
TheLlama's Avatar
TheLlama is on a distinguished road
I would not do this. Although that makes sense, when you connect it to your computer, the data signals will be off by 5v (since the computer has a 0v GND and the display has a 5v GND)
If it wasn't for the two devices being connected, I'd say go for it
TheLlama is offline   Reply With Quote
Wild Things PSone LCD to PC godzi11a LCD/Display 17 11-22-2005 08:13 PM
FS: Tablet PC (8" TFT LCD) BimmiN Classified Archive 10 10-25-2004 01:04 AM
Finally some success with LCD psone screen PierreLo LCD/Display 0 06-29-2004 05:53 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
Car Environment Temperature vs LCD screen, PC?? dekodan General Hardware Discussion 4 08-01-2001 03:46 PM
