Old 02-09-2005, 11:15 PM   #1
yellowfellow21 is on a distinguished road
Help with soldering PSOne in DC area?
Hey guys,
I have never solder before and I tried it last night. Oh man, it was so hard. I was wondering if anyone here are in the DC metro area that knows how to solder. If you could help me and solder the VGA cable to the PSOne I would really appreciated. I have already taken the PSOne apart and stripped the wires. I just need someone to help me with the soldering.
MOD: If I posted this in the wrong section, please move it for me. Thank you,
yellowfellow21 is offline   Reply With Quote
Old 02-10-2005, 12:35 AM   #2
cbergeron's Avatar
cbergeron is on a distinguished road
Soldering is _not_ difficult.
You should probably just have someone show you how to do it.
Here are a few tips:
1) WAIT until the iron is HOT before trying to solder. Don't try and solder when the tip isn't completely hot - you'll get strange results. Turn the iron on, wait for 10 minutes (I know that sounds like a long time for you young guys; but it's really worth it).
2) Use small guage solder - particularly if you're soldering something with small contacts like a VGA cable.
3) "Tin" the wires first. After you strip the wires, take each wire and feed solder/flux (usually the same thing) into it as you hold the iron to the wire. Hold the iron there until the wire changes from copper to "silver". Then tap the wire or flick is so the excess solder flys away / off. It won't hurt you; but definitely wear glasses when soldering (normal eyeglasses work fine).
4) Apply a small amount of solder to the board and while it's hot, connect the wire. Keep the iron on the "joint" / connection point until they both seem like liquid. Now, remove the iron, _while_ holding the two peices together. This is the hardest part - keeping the 2 peices together while pulling the iron away. Use a weight or something to prop everything together.
5) *** DON'T use too much solder. It doesn't take a lot to make something stick. The trick is making what is there melt and holding it there while it drys (usually 2 seconds or so). This is probably where most people make mistakes. It's much easier to add small amounts of solder than to remove it from a 15 pin VGA cable that is completely soldered into a big metal blob. ***
6) Just try soldering random **** together. Take a couple of wires, solder them together, etc. After soldering a dozen wires or so together you'll start to figure out how it works. It's not rocket science. It's much easier than welding, etc. because you don't need special goggles, etc.
My best advice to you is to just experiment on some other things before working on your VGA connector. After screwing with it for like 30 minutes, you'll figure out how easy it is.
Have fun!
-CB
DashPC - The Linux Car (since 1999).
Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
As seen in the book Geek My Ride
cbergeron is offline   Reply With Quote
Old 02-10-2005, 12:40 AM   #3
Thanks a lot for your input. I got very discourage after trying and trying and it didnt work. The "liquid" keep sticking to the iron instead of falling off and stick to the two piece.
Thank you, I'll definitely try again and I hope I can do it this time.
Old 02-10-2005, 12:44 AM   #4
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
flux
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 02-10-2005, 10:05 AM   #5
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Stick to the iron because the part/wire isn't hot enought and/or the soldering iron is not hot enought. Try brush the part with flux first. It makes it easier to stick.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-22-2005, 12:51 AM   #6
cbergeron's Avatar
Yellowfellow - it sounds like you're using an old soldering iron, an iron with a bad/old tip, or possibly a very low power soldering iron.
I paid about $40 for a Weller, and it's definitely worth the money. The Radio Shack models are ****ty, and they can make soldering/electronics seem like they aren't fun. Try using a good soldering iron, and you'll find electronics to be much more enjoyable.
$40 might sound like a lot, compared to the $9 radio shack stick; but if you consider that it'll open up a new world of computing/electronics to you - it's a very small investment. Also, the iron will probably last you 10-15 years or more.
It nothing else, try getting a brand new Soldering iron tip ($2.99 at Rad Shack for their model) and some small solder (I use the radio shack solder (60/40 .032 diameter).
Be careful with the Radio Shack iron; it's not well balanced and if you're not careful you could burn down your dorm/apartment/mom's house/whatever.
Kind regards,
CB
Old 02-22-2005, 01:46 PM   #7
cbergeron- Yeah, you're right on with what you said, it is old, it's not even mine. Someone gave it to me and I did not know whether it makes any difference between what I got and something more expensive. You're definitely right though, the tip is old and have left over solder on it. Thanks a lot for your input.
Old 02-22-2005, 04:37 PM   #8
hannibal is on a distinguished road
yellow, sent you a PM (sorry, I havent been on in a while)...
I tried practicing with my $9 Radio Shack soldering iron. It was very tough to make a decent connection. It barely got hot enough to DEsolder a connection. This was my first try, but I wish I had seen CB's suggestion about spending a little more for a quality iron.
My first carPC!
MP3/CD player
Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
Soon to actually find its way into the car!
hannibal is offline   Reply With Quote
Old 02-22-2005, 08:24 PM   #9
Here are the pics I mentioned...
My first carPC!
MP3/CD player
Wild Things PSone LCD to PC godzi11a LCD/Display 17 11-22-2005 08:13 PM
DC area Meet in January? Katya MP3Car Gatherings 108 03-04-2005 09:34 AM
Help with soldering PSOne in DC area? yellowfellow21 Off Topic 2 02-10-2005 12:34 AM
Maryland/PA + DC Area? malcom2073 MP3Car Gatherings 0 09-21-2004 07:52 AM
DC to DC converter jdub421 Power Supplies 3 02-03-2004 04:17 AM
