Old 02-11-2005, 07:16 AM   #1
Acid burn is on a distinguished road
Is 640x480 stupid on a xenarc ?
Yo fellows ,
I am encountering the following problem, i am using a xenarc 700 TS on a via epia10000 board, the board and the xenarc is powered by a OPUS 90W. Now when i put my resolution on 800x600 or 1024*768 on 75Hz, 1/2 of the time the xenarc does not behave like it should : it replaces the screen image about 3-4 cm to the right. the only thing i can do is auto adjust the screen by the buttons on the screen. no the problem is, i have bondo'ed these buttons away. The only solution i found was putting the screen on a 640x480 resulotion on 60Hz, now the screen always shows the image the correct way. I am using frodo as front end, and frodo turns out to work great on 640x480, but i would prefere runing it on 800x600 because this is te resolution most skins are build for. Are there any solutions ?
thnx in advance ....
Acid burn is offline   Reply With Quote
Old 02-11-2005, 07:29 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
try changing the refresh rate
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 02-11-2005, 08:12 AM   #3
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
I would try 800x600 at like 70hz. and there is no way at all you can get to the buttons?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-11-2005, 10:19 AM   #4
maronoff is on a distinguished road
800x600 at 60Hz doesn't work for you? That should be the refresh rate at which the Xenarc is happiest (as is the case with many, many LCD panels), and I've had no autodetect problems at that res. Not to imply that you don't already know this, but as LCDs don't flicker the way CRTs do, there's not much point in running the Xenarc about 60 Hz. Hope that helps...
maronoff is offline   Reply With Quote
Old 02-11-2005, 06:55 PM   #5
PatO's Avatar
PatO is on a distinguished road
You need to get those buttons back...
http://www.jeepmp3.com/
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 02-11-2005, 07:57 PM   #6
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I think your only solution is to get at those buttons....
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-11-2005, 08:08 PM   #7
Dem0s is on a distinguished road
Why did you get rid of the buttons in the first place?
Dem0s is offline   Reply With Quote
Old 02-11-2005, 09:57 PM   #8
Registered User
aoLhaTer's Avatar
aoLhaTer
Dont the Xenarcs come with a remote?
aoLhaTer is offline   Reply With Quote
Old 02-12-2005, 01:48 AM   #9
Don 944 LA's Avatar
Don 944 LA is on a distinguished road
pinhole through the bondo to actuate the buttons .... why bondo over them anyway ??
Don 944 LA is offline   Reply With Quote
Old 02-12-2005, 11:29 AM   #10
first of all thnx for the reply's
second : I can get to the buttons if i really wont to, but i need to do this 1/2 of the time... (auto adjusting the screen) and this is really frustrating me. now i am running at 640x480 and i don't need to do it any more ... but i would like it more running at 800x600 .....
Xenarc direct cause of audio noise- help! shidarin LCD/Display 5 04-19-2008 10:53 AM
Stupid Xenarc! It won't turn on when laptop is on or display correct!! PDiddy General Hardware Discussion 18 01-17-2005 08:53 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 04:11 PM
