Old 10-11-2005, 12:32 PM   #151
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Hi TC,
I am a bit of a bodger when it comes to electronics but i have a few ideas for a rudementary design. Jerry is the guy that wants to do all the fancy PICs and what not and the frodo and the guys from AIMEE want to do all this crazy PC controlled stuff.
If you use msn we should have a chat some time. Maye sure you have the latest version se we can do some sketches.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 10-11-2005, 01:33 PM   #152
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
with all the posting you do here, you still have time for im
I don't thave im,.... I downloaded trillian once but never screwed with it much......
I found this on a quick search...... this is why you would need to go with fancy electronics..... you need to read the referance voltage created, then convert to a usable pwm signal........
mine is different...... my pwr supplys already do all the dimming.... they need a variable resistance to control intensity.... with three I need around 2.5-3k resistor to control brightness..... I can trim & overide within the circuit, theres no logic involved.... a photoresistor is just that as far as I know, don't know the values yet, but this should be a google away....
this resistance is from 0, which is shorted(max brightness .... >to 2.?k which will be full dimming without going out
I need a photo resistor that does 2k...... maybe more control with 1.5k? I think I'll have to try to get a few different & play....I could also put one of these in series with an adjustable to have an adjustable variable, I think I could also put a pre determined added dimming when the driving lights are turned on... say add .6K to circuit when lights turn on... this should be real simple unless these resistors aren't available in a range to suit my needs I think????....
finally, since my lighting is set up in three seperate zones, I could have three photosensors....... bottom, middle & top of screen....... this screen is huge & most of the time it's only the lower part that is washed out by the sun..... my backlighting can compensate by boosting only where needed..... the top of the screen is under a little bit of an overhang.... this may need a little turn down depending on ambient light..... I could have 1 main sensor for overall tuning, & then 3 seperate auto fine tuning sensors........... I set this up in three zones with this in mind.....so this would make this "a 3 zone liquid cooled led high-brite lvds narrowscreen"
maybe this can be done with logic, but through hardware alone seems to be easiest..... I don't think I could design a logic board myself, nor do I think I need it at this point..... it may sound complicated, but it should be eazy hope I'm right
turbocad6 is offline   Reply With Quote
Old 10-11-2005, 01:37 PM   #153
MySQL Error
our inverters will either have a 0-5V control line or a PWM in (or both).
I plan on making a basic system using an LDR and 2 pots. one will adjust the gain of the LDR and one will set the level allowing adjustment of the autodimming. it is just a theory at the moment but it shouldnt be too hard to achieve.
Old 10-11-2005, 01:42 PM   #154
turbocad6's Avatar
that sounds like it should work too, just building a bridge like the last that I showed should do it.... I wouldn't expect there to be any draw on the 5v.... if theres any sort of load at all then you may not be able too, but otherwise it sounds like it should work
Old 10-11-2005, 01:51 PM   #155
MySQL Error
no there wont be any draw. I am thinking some kind of simple circuit with a gain pot in parrallel with the LDR and then a level adjuster pot in series.
you then have a toggle to disable the LDR for full manual control and maybe have some sneaky relay trigger for a night mode from the HU wiring loom dim pin.
Old 10-11-2005, 02:22 PM   #156
turbocad6's Avatar
sounds exactly like what I'm doing, mine is a 5v reference too..... I guess there exactly the same when you think about it, your inverters take care of the actual pwm, my supplys take care of varying the mw output from low to around 350mw at max
have you looked at any ldrs? are they avail. in different ranges & configs??
Old 10-11-2005, 02:24 PM   #157
MySQL Error
that would be a no on the LDRs. as we only need to make a simple 5V signal i am not too worried. Everything else can be trimmed/bodged/tuned to match the LDRs
Old 10-11-2005, 02:38 PM   #158
Xander is on a distinguished road
Dude... How many computers do you have in your car?! Navigation on one screen, XP on another, and theres a third one (DVDPlayer?)
Xander is offline   Reply With Quote
Old 10-11-2005, 03:25 PM   #159
turbocad6's Avatar
that top screen is my rear view mainly... only one pc right now.......... gonna throw one in the rear for my kid I think soon though.... it may serve double duty as a self contained wireless hot spot router w/ my verizon broadband card to free up the only pcmcia slot I have on my front computer..... we'll see
Old 10-13-2005, 12:04 AM   #160
turbocad6's Avatar
I got the third power supply... put it in & it's all good..... been playing with this, I don't think I will need to or want to do three seperate dimming zones.... it just better overall if it's evenly dimmed..... I played with trying to get the alpine screen & the pc screen to look as similar as possible.... a few screen shots
Old 10-13-2005, 12:08 AM   #161
turbocad6's Avatar
theres a lot of room on this screen.....
Old 10-17-2005, 12:44 AM   #162
turbocad6's Avatar
had this in for a week now....& it's been raining for a week too, so I haven't been able to really see what it can do in bright sun.... this weekend was beutiful though & I finally got to test this..... the alpine screen is shrouded so it's real hard to wash it out completely, but you can see that where the sun does hit the alpine upper screen, it is washed out..... the computer screen though is very readable..... it looks pretty wild in person to see...... the only time I've ever seen anything like this has been on an itronix laptop that I used to have with a transflective b&w display....., I couldn't get this to wash out no matter what I did.... I couldn't ask for more really.... just gotta hope the touchscreen don't change this too much......
now I can finally remove the 5% limo tint from my front windows, 15% will be fine I think
Old 10-17-2005, 01:35 AM   #163
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
raining here? what are you talking about been sunny here for weeks :-P
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 10-17-2005, 01:40 AM   #164
Raw Wave
by the way the screen looks great you can put 3 ts overlays on it and probably see no difference
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 10-20-2005, 12:22 PM   #165
MySQL Error
well he wont see **** if he gets a glare problem.
Looking good TC.
