05-11-2006, 02:49 PM
#226
Laptop, Tablets, UMPC Moderator
o.k., now it gets interesting..... I'ts been cloudy & it's suposed to rain all weekend....
it looks good during the day when it's cloudy & overcast,I'd like to see this in the sun in my car to see if it overall looks at least as good as my alpine screen, which I guess I'd be satisified with... but best chance of that won't be until at least monday according to the weather guessers...
I did get to see it briefly in direct sunlight out of the car & it is viewable, but at the same time very dim looking..... it looks like theres no backlight really, but you can see the images on the screen anyway... so I figured what the hell, let's take it apart & highbright it with the luxeons anyway.....
so I start to take it apart... remove the bezel & the first thing I notice.... theres no wires going to the digitizer glass?!?!
I fire up the laptop & the digitizer still works without the glass! I then lay a glass capacitive overlay over the lcd & guess what, it works with the pen even with a capacative overlay!!!!! why the hell wouldn't the manufactures build them this way.... I mean with a digitizer & a capacitive touchscreen at the same time a tablet would be even more apealing, & it works!
ok, so I remove the lcd.... it turns out that the digitizer is actually built into the lcd, not the front glass.... the problem is it's built into the rear of the lcd, a metal plate with a board.... this means that I can't do this one like my last with the luxeons unless I try to seperate the digitizer from the lcd itself.....
while I may be able to do this, I also run the chance of ruining this one.... my last lcd I am replacing for $110..... so ruining it wasn't such a big deal..... this one cost me over $1,400 taxed & shipped.... I got big balls when it comes to butchering & modifying electronics, but I'm not wreckless either.... this one scares me a little...add to this the hinge is a funky design & controls the orientation of the display... I don't even know yet what I'd have to hack there as I didn't disassembe the hinge yet, so I put it back togeather for now....
so now I have 3 choices.....
1) replace the screen I had.... use it as it was, it was perfect to the driver, super bright & always visable regardless of sun... I'll just tell everyone it's a security screen ment only for the driver to see
2)put this tablet in, as-is without butchering it.... it will be very viewable from all angles, & still viewable regardless of the sun, BUT it's not super bright like my last one......
3) push my luck, throw all thoughts of reason out the window, cross my fingers & try to seperate the digitizer... disassemble the lcd, cut out the rear & luxeon this thing too... all the while running the risk of ruining the whole thing.... this lcd is REALLY ireplacable... back when I first did the dell it was not readily available, but today there out there all over, this hydis lcd isn't....
so what's better, a super bright lcd that's only visable to the driver or a dim but sunlight viewable one that's visable to all?.....
****... I still don't know what I'm doing with this
05-12-2006, 12:10 PM
#227
....I took the dock apart & it's not really good to work with either.... it's all one board & I can't do what I originally though of, turning the connections back rather than to the side as it is now..... the way it is now isn't usable, the connectors would stick out way past my console..... I thought I'd be able to do something with it, but not really.....
this tablet convertable is pretty cool, but it's got a few things against it when it comes to installing in the car....
this is frustrating... at this point I'd spend whatever necissary within reason to come up with a good solution, but I still haven't found it.....
not going portrait is not really an option, the largest I can go with that is like 8"..... after my last screen I don't want to downgrade that much screen size..... a big screen that fits well is awsome & I have the space in portrait mode..... just can't hit the right solution.... maybe I should have gotten a regular tablet instead of a convertable.... they dock different & are available with the same screen.... back to ebay to look for a different model????? that could be a last resort
putting the original screen back in is starting to look like the sanest option...... I think I'll look some more into film enhancements...... there are possibilitys still there, but finding someone to actually bother with one piece is tough , I haven't found anyone yet except nathan at fpd, who gave me the quotes I stated earlier.... if he said $700 would definatley do it I would go that route, but he didn't seem too optimistic about it...
still don't know....
ooooh, the sun is out, I'm runing to the truck to see this in the sun...
05-12-2006, 12:37 PM
#228
Motion have just released their bigger slate with a touch screen. I'm not sure it can be configured with the view anywhere screen however.
05-12-2006, 01:39 PM
#229
yeah, it is available,... they use the same screen... cost more & have much less horsepower than the fujitsu I picked, but it could be a good option at this point...
in the sun this screen looks good..... yeah it isn't as bright as the old one, but it looks perfectly fine really, even in direct sunlight.... it's impossible to wash it out.... it's a little dim overall, but I got used to insanely bright...this is not bad really...
so now it would all come down to dockability, which this one isn't good at at all... gotta look at the way the different choices dock..... but it's hard to tell which dock setup will work best without seeing them in person, & even then, hard to know until taken apart....
I don't want to have to buy a bunch of tablets to find the right one.....
gotta look at the way motion & fujitsu dock there different tablets....
05-12-2006, 03:50 PM
#230
The motions have a large connecter on the bottom (landscape). Then the dock connects to that and exposes usb, lan, sound & power connections. I'm looking an LS800 with view anyhere with an eye to whether it would be ideal fabbed into the dash but it really needs to be a touch screen which probably then screws up the view anywhere benefits.
05-12-2006, 04:22 PM
#231
no, the built in touchscreen/digitizer isn't a problem too much.... actually theres just a plastic glass cover that looks like it has a slight purplish tint, like it's polarized coating maybe.... but not heavy like a toughbook would be... this cover isn't even the touchscreen though, the digitizer is built into the lcd & if you took this cover off your down to the raw lcd... you'd need it covered anyway to avoid scratching the lcd though, & the lense they use is probably fine left in place.
you do know that you'll have to use the pen right?... if it was permanently installed you could put a regular touchscreen over it... is that what you mean?
05-13-2006, 04:46 PM
#232
o.k., I think I'm on to something here.... I have been able to find a source for these BOE Hydis lcds.... I have learned through this source that Hydis also currently makes a 10.4" lcd with the same properties as the 12.1... 180 deg viewing angle all around & indoor/outdoor tech....
that by itself is just interesting, but actually using the screen is another story.... this is where it get's even more interesting.... I recently bought a few gateway tablet motherboards to play around with building carpc's from them... turns out there lvds too of course... these should be compatable with these screens,all the same specs.. 1024X768,1 ch lvds, 3 data, 1 clock.... but data sheets for both the lcd & the motherboard would have to be obtained & custom cables built.....
well I found someone who has this ability.... I am shipping him one of my gateway motherboards next week & he will attempt to get the hydis to run off it & build a custom cable... if this happens then I have developed a way of providing a carpc that's tiny, efficient & includes the best lcd's on the market for pretty cheap.... even if I build stainless steel cases for the motherboards, all said & done a bare bones system would probably total maybe $1,200 or so... including the pentium m processor & a sunlight viewable 10.4" lcd... just add ram & a hardrive & power supply & your good to go.... I think there'd be a market for these..... I could also provide a turn key solution including all hardware & a legal operating system for maybe $1,700 or so.... I think there'd be a market for that also... I haven't seen anything that is comprable to this anywhere.. sure the 10.4 is a little on the large side, but it isn't any wider than a standard 8" when used in portrait mode.... this should open the possibilities a bit for installing in more vehicles...
right now there is no solution on the market like this for this cheap.... I think I could develop & sell a few of these..., but this isn't my primary objective here originally.... I want to get one of these set up for my car.... if that works out well then I may explore the posibilty of marketing it...
the 10.4's don't have a digitiser attached... I would ultimately like to be able to mount this lcd on my luxeon box, then I'd have the best screen currently available anywhere...., even $4000 aircraft screens would have nothing over this one, actually mine would be better by having 180 deg viewing angle all around & of course it would be usable under any ambient lighting conditions
maybe then I'll be satisified with this
06-03-2006, 01:36 AM
#233
I got the new lcd.. got a controller & got it wired up.... gutted the lcd & prepped it for rear lighting... here it is on the luxeons. this screen is dramatically different from my first screen... this screen looks great no matter where I look at it from... this screen also seems to have MUCH MUCH better color while being boosted with backlighting.... it has a very high contrast ratio & looks way better than my last one...
06-03-2006, 02:40 AM
#234
Looks nice.
I've been driving round with a Motion LS800 propped up in front of my crappy Lilliput. It's a gorgeous screen. It looks like I've got a piece of laminated plastic there. The only time I can't see what's on the screen is when the sun is exactly at the right place to be reflecting directly off the screen and into my eyes and I only have to move my head a little / turn the car every so slightly to workaround that.
And I've found that the dock will fit happily in the hole where the dashboard mini-glove box is in my Subaru with all the ports easily accessible at the back of the dock. I've been imagining the dock all nicely fibreglassed in and I think it will look very nice. Not OEM in the usual sense but for a PC you could take out of the car in a dodgy neighborhood or take into the house to continue to use, it's probably a nicer experience all round.
So I've been thinking about how much I really want touch. Using a pen isn't too much of a hardship and it would keep my greasy fingers off the screen.
06-03-2006, 10:17 AM
#235
yeah, I did the same thing with my tablet.... it is very viewable, but not too bright... these screens are awsome for viewability, but I haven't played with the smaller ls800.... I really was considering getting one to play with, but I wanted larger... I know what you mean about looking like a piece of laminated plastic... I say it looks like a piece of printed paper but your discription is probably a bit closer to what it looks like...
using it with the pen might not be so bad on a perminent install, or if you want to go nuts you can possibaly have a cover flip down to dock , then the cover flip back up over it... the cover has a glass window in it that covers the screen & it would be a capaciative overlay... that could be a nice setup if you have the space...
06-03-2006, 11:20 PM
#236
Looks unbelievable with the luxeons. Have you seen the "7.7" DXD 10X12"(2816×3584)" that Boe Hydis lists under "specialized applications"? Any chance your source stocks that one?
06-04-2006, 01:43 AM
#237
I think once you put your typical capacitive touch screen in front you'd destroy all the sunlight readability. I think I could get used having to use a pen. And it would be a far easy fabrication job to fab in a chopped up dock. Plus I kind of think the LS800 would look cool sticking up out of the dash with no housing around the back of it  .
I'll try to take some piccies tomorrow to give people an idea of what it would look like. The LS800 may not be cheap but it would solve so many of the Car PC problems that generally plague people.
One thing I haven't yet worked out how you'd do is automatic turn-on or for that matter how you'd do 12->19V DC-DC conversion to charge/power it.
06-04-2006, 09:48 AM
#238
no, I have a good capacitive touchscreen & it has an anti-glare coating.... doesn't hurt sunlight readability much at all... a typical resistive screen would be pretty bad I think... & I guess a pen wouldn't be bad... just keep it teathered... would suck to drop it between the console or under the seat while driving... I did that more than once while testing...
you can use a carnetix p1900 to power it, & start it up/ shut it down & provide power for your usb stuff too...
if the dock has a switch you can hack that easily enough, if not, you may need to open the tablet to get at the switch.. might be a little hairy hacking that apart though, I already disssasembled & reassembled my tablet the first day I got it, some don't like doing this though
I think you have a great idea... I considered the same thing, but I want a bigger screen, plus I wasn't to sure how the ls800 screen compared to the larger screens.. it doesn't have the same ultra wide viewing angles...
06-04-2006, 10:00 AM
#239
I'll ask about the "7.7" DXD 10X12"(2816×3584)" that Boe Hydis lists under "specialized applications"
I haven't seen it... I'll google it later & check it out.... hydis has a few awsome screens that are listed as "under development"... including a real sweet 1280X800 12.1" widescreen that would have been a perfect replacement for my prior screen.... just don't want to wait for what could be 1/2 a year or more
06-07-2006, 06:57 PM
#240
Coldplate for LEDs
The coldplate that you used to cool the LEDs on your LCD is exactly what I have been looking for. Where did you purchase it at, if you don't mind me asking?
| Thread Tools |
| Display Modes |
Linear Mode
