09-21-2005, 09:39 PM
#91
awsome
09-21-2005, 09:51 PM
#92
Super Moderator. If my typing sucks it's probably because I'm driving....
these might be brass rods.... kinda like brazing rather than sweating...
the plate assy tranfers so much heat that I can hardly get each connection hot enough.... so much for a pretty looking box, it looks like a barbeque at this point
two more leaks sealed, waiting for cooling..... it takes a long time because this is like like 20LB's of copper/aluminum, the copper plate is awsome for heat tranfer... this backlight is going to work awsome...... if I ever finish it......
09-21-2005, 10:07 PM
#93
another leak.....cooling...........................
09-21-2005, 10:14 PM
#94
Raw Wave
there's nothing like trial and error. Makes the project much more valuable...
09-21-2005, 11:01 PM
#95
lcd barbaque..... but holds 150 psi, all except for one fitting, I'll fix it tommorow
09-22-2005, 12:38 AM
#96
wow, I just re-read this thread & realized that it's been 5 months since I started this, & 4 out of the 5 i've had no pc in the car
I think it should be back in final real soon, can't wait to finish the bezel & paint it & call it done,,,,
I,m undecided still whether I'm going to paint the dash bezels matte silver grey, or gloss black..... I have a new odessey in the shop this week & it has gloss black trim bezels.... it looks pretty slick..... might just go that route
10-02-2005, 03:17 PM
#97
LOL Turbocad, ya got enough screens in there?
Looks neat!
I kinda like the idea of seperate screen for reverse/forward looking camera's..
I'd love to get a forward looking infared or night-vision camera...
10-02-2005, 08:06 PM
#98
I epoxied the lines to reinforce, seal & make sure it never leaks.... it sits right above my pc so a leak could be trouble more than just a wet carpet
it's pretty close to done, just have to finish the final lense & mount up & wire the led's....
first I used a liquidy flowing epoxy to fill any leaks & all crevices....
10-02-2005, 08:10 PM
#99
then I reinforced the tubing structure with a stronger epoxy....
10-02-2005, 08:15 PM
#100
cleaned prepped & painted the whole inside with a high heat engine paint..... used a nickel at each led point so the led's will directly contact the copper with heat transfer compound....
10-02-2005, 08:19 PM
#101
ready to final screw in the led's....
10-06-2005, 05:55 PM
#102
That is awesome! Looks great, should turn out really well with all the time you've spent working on it.
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
10-06-2005, 06:14 PM
#103
Fusion Brain Creator
Use a heatercore instead of a tranny/oil cooler. save $80.
10-06-2005, 06:27 PM
#104
heater core less durable to outside in grille elements, thicker to, & not nearly as easy to mount..... a tranny cooler will be the cleanest & most reliable way to do this.....
10-06-2005, 06:41 PM
#105
Why mount it outside?
Just as easy to mount, run threaded rod through it
so what if it's thicker?
oh well, your money
| Thread Tools |
| Display Modes |
Linear Mode
