Old 10-06-2005, 06:42 PM   #106
Fusion Brain Creator
greenman100 is on a distinguished road
then again, you dropped over $100 on copper plate when alumnium has a similar thermal conductivity and 1/10th the price
greenman100 is offline   Reply With Quote
Old 10-06-2005, 11:56 PM   #107
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
copper is a better heat conductor & will provide an extra ounce of protection for the leds..... spent more got more.... I guess aluminum may have also worked, but I wanted copper to pull the heat away from the led's that much quicker.... without testing in advance there was no way of knowing what would have been adiquate & I would rather error to the side of overkill than not enough I guess
the cooler has to go outside of the cabin...... I want to remove the heat from the cabin, not just move it from the dash to the interior & I don't want any fan noise... I thought about mounting it undernieth the truck but airflow is tricky & I don't want to pull engine heat across the cooler & it's more subject to abuse under than in the grille..... I'm working with a 3/8" inner diameter tubing & a heater core will not be as good a fit as a trans oil cooler, & where are you getting $80 savings.... a heater core is going to be $45 at least & a decent tranny cooler shouldn't be much more than $60 or so.....
turbocad6 is offline   Reply With Quote
Old 10-07-2005, 01:41 AM   #108
Vinister is on a distinguished road
How come in your pictures the laptop screen on the left looks much brighter than the LED creation? Why not just use that screen instead?
Vinister is offline   Reply With Quote
Old 10-07-2005, 04:03 AM   #109
86 Chevette heatercore is $20 and 36 sqin
bonneville heatercore (72?) is 60 sqin and $24
and you cited the cost of the oil cooler as $100
Old 10-07-2005, 10:09 AM   #110
turbocad6's Avatar
hmm, makes sense I guess....
I'd rather spend more & get more though..... that's really the whole point of this project..... if I wanted less & to spend less I would have just left the lilli in there...... I am trying to do this as good as it can possibaly be, I fully expect it to be awsome
I could have sourced a cheaper light source, I could have sourced a cheaper pc.... I could have used wood or cardboard & fiberglass/bondo instead of bying multiple dashboard bezels.....
this is not about doing it as cheap as possible...... it costs what it costs.....
I will have well over 40 hours labor in this pc upgrade including the screen..... the last thing I want to do is cut corners.....
in the end this will be a high end install...... & there not cheap to do.... it takes what it takes
Old 10-07-2005, 10:59 AM   #111
turbocad6's Avatar
that picture is with 20 leds, final will be 32..... it's also no where near as bright although it may look that way in the pictures because the color is so much better on that laptop screen....
that modded screen lights up the room..... the laptop is not even close.....
the color is the main difference.... the screen in that picture still has the heavy red cast from the copper & I played around with gamma..... in person you can clearly see the brightness difference though..... major difference, that laptop also happens to have a really nice display btw
one of my concerns with a screen this bright is color washout..... but that's really only a problem when really cranked up...... if the choice is to either see nothing during the day in sunlight or see a washed out screen, I'd rather at least be able to see it, which is the whole reason for this in the first place....
under normal conditions this screen will not be cranked up all the way, so this isn't much of an issue.... after this is in is when I will have to start working on the auto dim with photo sensor
Old 10-07-2005, 11:01 AM   #112
turbocad6's Avatar
also with the better dispersion of the 32 led's over the 20 I will need less diffusion, which will also increase the brightness
Old 10-09-2005, 02:26 AM   #113
turbocad6's Avatar
these led's are awsome if there spaced right, the first test was with not enough leds to give total light coverage & needed a lot of diffusion
I then set out to fill all the dark voids with leds
I left the original pattern upgradeable, good thing too because now it is PERFECT
spacing & distance are the two main variables that will allow an even light distribution without need for excesive diffusion, the upgraded patern looks like this, this is with no aditional diffusion other than a sanded freznel lens.... the original pattern had hot spots so bad that I needed to add a sheet of paper to get good dispersion, but this also cut the light down quite a bit
now this thing is BRIGHT
this is the lcd lit with no display
Old 10-09-2005, 02:34 AM   #114
turbocad6's Avatar
this picture is AFTER I blew out one of the three power supplys for these led's......... there are only 21 lit..... the whole top three rows of 11 more are out completely in this picture........
remember, this is only the bottom 2/3 lit.... 21 on & 11 off ...... the laptop is cranked full bright for comparison
here you can clearly see the even light distribution & how much brighter it is, the top of the screen is slightly darker because of the above mentioned problem
Old 10-09-2005, 02:46 AM   #115
turbocad6's Avatar
now I will have to play with color & gamma..... of course this screen won't be run at full brightness all the time, when I turn the brighness down the colors are crisp & the display is really nice..... the dell 700m's have a nice display to begin with, I'm going to build an auto dim circuit with a photo sensor......
when it's bright & sunny out, & the tinted windows are down...... I should still be able to see this screen,,,, sucess!!!!!!! as that was the main goal for this backlight......
Old 10-09-2005, 02:57 AM   #116
turbocad6's Avatar
I've looked at some stupid expensive screens that are used in helicopters & such.... all things considered if this whole thing came in at a grand belive it or not it's a BARGAIN.....
as far as sunlight readable displays go, this is NOT expensive.... add to this the fact that it's an lvds screen directly run off my motherboard.... AND the fact that it fits my dash perfect..... AND the fact that it is pretty unique.... I don't regret one penny spent here really
Old 10-09-2005, 03:53 AM   #117
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
damn, that looks good. Can not wait to see it at the meet. And you are right on the cost, my allbrite sold for over $1500+ when it was new. And I do not have the dimming capabilities you do (although i might start looking into rigging something up). Plus you get the gratification of working on a project like this and learning along way.
and the fact that it is liquid-cooled is ridiculously cool.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 10-09-2005, 03:58 AM   #118
alti's Avatar
what are you using for diffussion, just the sheets the screen had stock?
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 10-09-2005, 11:40 AM   #119
turbocad6's Avatar
the lcd has everything it came with, minus the rearmost layer which was a reflector for the stock tube & not transparent. the only add'l diffusion is a freznel lens that I sanded with 80 grit to aid dispersion.... I still have this reflective layer & was thinking about using it in the box. I would cut holes for the led heads to poke through them. this may help a little more although now that the box is all white inside it may not make a huge difference..... it will cover the black of the led's themself & the wiring, but I did all the wiring white too so again, maybe not much different........
I also thought about adding a mirror here instead.....with the led heads poking through.... but it would have to be almost paper thin to not affect the radiating pattern of the led's. if I could get a mirror in there it may help under high ambient light conditions by acting transflective, but I don't know how it would react by being about 1 1/2" back from the lcd itself, that would be pretty experimental & I may play with it when all else is done....
I tried it without the freznel also & it doesn't make much difference, it also doen't cut much light at all so I decided to use it.... it will also aid in keeping any radiated heat from the lcd by insulating/isolating slightly
this is the inside witout the lcd or freznel
Old 10-09-2005, 11:44 AM   #120
turbocad6's Avatar
this is with just the freznel....
