Old 03-11-2005, 05:15 AM   #1
Dell laptop, lilliput screen, and 800x480 resolution, possible?
I am in the process of putting together a carpc, but am not sure if I will be able to get native resolution on the lilliput with my dell laptop.
I have installed powerstrip, but am not familiar with the exact setup or if it is even possible.
Also, I have read long and hard and could not find a specific enough answer for my particular case.
Thanks.
sivart321 is offline   Reply With Quote
Old 03-11-2005, 06:42 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
Thanks.
Go to the advanced options of your display properties and select list all modes. It will tell you whether you can display at that resolution.
You can also uncheck the option to hide modes that the monitor can't display. Windows won't pick up your Lilliput specifically, but as a default monitor.
And you want it at 75hz, I believe, not 60hz.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 03-11-2005, 07:03 AM   #3
Registered User
mpattonm's Avatar
if you fail finding 800x480 listed under "list all resolutions" button, you may want to try your luck with PowerStrip too.
mpattonm is offline   Reply With Quote
Old 03-11-2005, 10:46 AM   #4
I don't even see "list all modes" anywhere
nm, found it... not there :-(
What do I need to do in powerstrip to get it to work?
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Lilliput 7" @ 800x480 ryguy LCD/Display 6 12-19-2004 07:11 PM
WMP full screen resolution Maņana Software & Software Development 0 09-04-2004 03:29 AM
Help solve my resolution problem on my 7" Lilliput!! CDL0012 LCD/Display 0 06-14-2004 11:01 PM
800x480 on lilliput 7" / linux? hkrebs LCD/Display 1 03-25-2004 02:58 AM
