03-21-2005, 12:46 PM
#1
800x480 vs 848x400 Pics
Can somebody please post some pics of what a 7" lilliput runnning at 848x480 and a 7" lilliput runnning at 800x480 looks like? Id like to see the difference as I am about to purchase a MB. If 848x480 looks good enough to me Ill just pre-order a Epia SP. If 800x480 is that big of a difference Ill probably get a M1000 and throw in a NVIDIA card. Pics of typical apps run in windows would be appreciated.
03-21-2005, 12:55 PM
#2
Don't have pics, but 848x480 looks like **** on the lilliput, 800x600 looks alot better. If you need a widescreen res., go for nvidia
1984 BMW 323i (E30)
[==========] 90%
EPIA MII10000
256MB RAM
40GB 2,5" HD
Lilliput 7" TS
Hacked Travla C134
Haicom CF GPS
#3
Registered User
OK, Ill just sign this thread to see the reactions
03-21-2005, 01:49 PM
#4
Jesus Freak
I'd like to see a side by side comparason too
03-21-2005, 03:29 PM
#5
Raw Wave
I've tried both in the past and I don't have pics to post BUT my Lilliput liked and locked onto the 800 x 480 with no problem where the 848 x 400 had to be adjusted every time through the Lilli menu. I just stuck with 800 x 480.
03-21-2005, 03:32 PM
#6
don't have a lilliput or pictures, but I have a xenarc and at 848x480 it looked horible, text was extremely hard to read and everything was blurry, at 800x480 everything is crystal clear.
VIA MII10000, 512mb, EVGA MX4000, Xenarc 700TSV, M1-ATX PSU
G.Skill 64GB SSD, Panasonic slimline slotload CDRW/DVD ROM
03-21-2005, 03:59 PM
#7
Thanks for the opinions guys but I've read dozens of them in the other threads, just really lookin for pics in this one.
03-21-2005, 07:01 PM
#8
Jesus Freak
What is the exact model video card you used and what is your settings? are you using power strip.
03-21-2005, 07:38 PM
#9
Raw Wave
I have an ATI Radeon 9200. If you load powerstrip and add the resolution. When you reboot and set it you don't need powerstrip to load so you won't get those "register" pop-ups when loading windows.
You can get the 800 x 480 resolution out of any Radeon or GeForce card.
03-22-2005, 02:52 AM
#10
Jesus Freak
...If you load powerstrip and add the resolution. When you reboot and set it you don't need powerstrip to load so you won't get those "register" pop-ups when loading windows...
hrmm I am a little unclear on your post. When you set what and where?
...my Lilliput liked and locked onto the 800 x 480 with no problem...
My amazment is that your lilliput locked on to 800x480. Are you sure... that resolution gets confused all the time.
The reason why i am asking details on your setup because the problem is not getting a graphics card (except the via m10k onboard) to display a custom resolution for instance 800x480 (the native resolution for the lilliput and xenarc) it is having the monitor recognize it and lock on to it as 800x480 instead of seeing it as some other resolution and displaying it incorrectly.
Also why would you just "settle"for that resolution? What you are claiming to have is the holy grail my friend.
I think it is time you busted out a digital camera and showed us a picture
03-22-2005, 07:46 AM
#11
Raw Wave
800x480 will look infinitely better than 800x600 which will look infinitely better than 848x480.
You notice the vertical "squashing" much less when running at 800x600 than you would do with the horizontal "squashing" you would get with 848x480
600 pixels goes into 480 pixels MUCH nicer than 848 goes into 800.
I'll see if I can get some pics over the next couple of days.
Garry
03-22-2005, 09:24 AM
#12
Raw Wave
I am positive. I've been running that res for quite sometime now. If you just install powerstrip and go through adding the custom resolution, I think it's listed as "800 x 480 LCD", you should have no problems. I've done it to more than one setup in the past.
I think you took my last comment a few posts up as me "settling" for 800 x 480. This is not the case at all. I used to think 848 x 400 was the ultimate res. but once I saw 800 x 480 and how my Lilli liked it...well, you know the rest.
I will attempt to take a picture tonight but my current system is in my closet as I bought a new car and I am figuring out how to install the carputer in this one.
03-22-2005, 09:44 AM
#13
Raw Wave
Providing you're not using an Epia board with the onboard graphics - because it doesn't support any custom resolutions.
Especially as 848x480 is totally the wrong resolution for the 7" displays, and either 800x600 or 800x480 will be better.
I'm going to try to hook up my Xenarc when I get home to my main PC with a Radeon 9800 Pro in it (as it will do custom resolutions) and try to get some comparison shots.
Garry
03-23-2005, 12:59 AM
#14
Jesus Freak
I hope you dont mind if I PM you sometime when i get to setting it up for some details.
I would appriciate any pictures any would post. Shoot if i could get my lilliput to lock onto 800x480 with any graphics card i will be stoked
04-16-2005, 07:32 PM
#15
All my emulators have to be played in a window b/c my Epia M10k won't recognize 800x480  My single complaint about my carPC...
CarPC #3: 99% CompletePentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more! old carPC
| Thread Tools |
| Display Modes |
Linear Mode
