Old 03-21-2005, 03:20 PM   #1
lakorai is on a distinguished road
StarVision VGA LCD displays
Hey all:
I am new to the MP3Car forums. I have a W-Body Grand Prix, like one of the other members on this site, and I would like to do a carPuter setup. I am shooting for a nForce 2 MicroATX setup with a power invertor right now running AMD Sempron w/ 1 gig of ram and a combo drive. NewEgg has a very nice InWin case that is pretty small (and tight for space) that might fit my glove box. I would really like a MicroATX case that fits in my glove box, otherwise it's going under the passanger seat with a power invertor and some L-Brackets to keep it moutner to the floorboard with a small piece of LDF fiberboard or 1/8" thick plywood.
Anyways:
Has anyone tried the Starvision VGA LCD Screen? (http://www.starvision.us/). They have 3 models available, one having a physical resolution of 1280x234. Anyone try these? I have a Starvision "Pixelon" flip-down lcd that works pretty well and has very good image quality and viewing angles.
Since there is only one 1.5 din opening, and I have a full system installed currently, I think I could really only mount a monitor using the dash (not going to happen) or usign a gooseneck. Any of the current monitors work with a gooseneck to the best of your knowledge? I am thinking about mounting the neck to the passanger seat. Pyle audio sells a gooseneck in 3 different heights.
I could remove the cigerette tray and place a flip out, but the problem is that the screen could only come out if I placed the shifter all the way back into drive or 1. And the fact that the Xenarc is $550 for a screen is also a bit much to swallow. From what I've read ther Lilliput monitors suck in daylight and have poor brightness/contrast. That is my biggest grip with car LCD's uin general - they are horrid in quality vs. standard LCD computer monitors or even LCD TV's for the home enviornment. The best LCD's I've used in the car are LUXMA's.
I want to use this for WiFi, Bluetooth mice/keyboard support, GPS using Streets and Trips and MP3 playback. MediaCenter 2005 OS will be used as the OS.
LAKORAI
97 Grand Prix GT TURBO
lakorai is offline   Reply With Quote
Old 03-21-2005, 03:37 PM   #2
Price of monitor
BTW - The Starvision SP-7VGA screen can be had online for cheaper than the LilliPut and is significantly cheaper than the Xenarc. Hope is isn't crap. Some of the cheap starvision/Pyle low end LCD monitors are junk. This one though has these specs:
7” wide screen TFT Color Monitor With VGA and Touch Screen
Computer Display/ DVD/ VCD/ Rear view Camera Compatible
Color System: NTSC & PAL auto switching
Resolution: 1220 X 234
Aspect Ratio: 16:9
Color configuration: RGB Stripe
2 Video Inputs, VGA input, Audio Input
Touch Screen Display (requires USB Connection)
AC adaptor included
AC, USB and headphone inputs
Full function remote with OSD
WebZone.us has this monitor for $229! I think I may buy it.
-LAKORAI
Last edited by lakorai; 03-21-2005 at 03:46 PM. Reason: Add info on Prix of Monitor
Old 03-21-2005, 03:52 PM   #3
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Well the "SP-7VGA 7” Full Color LCD Monitor with VGA Input and touch screen" is a lilliput - if you look at the picture!
The "SP-7VGAT 7” High resolution monitor with VGA Input & Touch Screen" looks like the old T-view - the 250nit one not the new one but don't quote me on that.
The "SP-VGA7 7” High resolution monitor with VGA Input" - i do not have a clue about but it
So going back to what you were looking at - it is a lilliput. Have you not noticed it looks the same????
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 03-21-2005, 10:12 PM   #4
robr is on a distinguished road
many of us are running starvisions, probably 20 people here bought them within a week during a group buy. no problems with mine at all, only complaint is it's a bit on the dim side (and the advertised dimensions are WAY wrong).
robr is offline   Reply With Quote
PS1 LCD VGA mod Summary... odin836 LCD/Display 26 01-13-2007 07:16 AM
Cheap working 9.6"Monochrome 640x480 VGA LCD screen & ISA controller card with cables Frank Grayson General Hardware Discussion 14 12-09-2005 04:03 PM
lcd or vga?? ninjaxryder LCD/Display 3 12-09-2004 09:08 AM
Can the PSone lcd be used with XBox once its VGA modded? xboxerxbox LCD/Display 17 10-24-2004 11:06 PM
10" vga lcd touch screen going for 350 us Mp3_Truck Classified Archive 1 06-16-2001 12:48 AM
