03-28-2005, 06:54 PM
#16
Quote: Originally Posted by joshthepilot
Otherwise you will notice poor quality in your display unless you have the usb also plugged into the computer.
That's exactly what I wrote in my second post
Quote:
I first noticed this when I was powering my Lilliput from separate power supply - not from PC's 12V. If you don't connect USB cable to PC - image is flickering. Bad ground.
I will probably make my own cable, but need to find 14pin connector first.
Anybody knows where to get it?
Anyway, I hope we  helped FireAnt . But he's quiet.
Dmitri
03-29-2005, 03:50 PM
#17
Astal,
Thanks, I'm going to give it a try tonight! I can't wait to use this thing again.
Mike
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
03-29-2005, 04:14 PM
#18
Rich Creamy Center
whoever made the images of the plugs with the numbers on could they possibly send me a high rez version without the numbers (not the usb or vga i know what they look like  )
ryanmtATgmail.com
So far - 1.1ghz athlon 4 Sharp Laptop, 256mb RAM, 20GB HDD, 32MB on board graphics. CDRW/DVD, 600W Boschmann amp, K301 InDash Screen
03-30-2005, 10:41 PM
#19
Astal,
It works!! after a couple of hours of soldering and heatshrinking it's fixed. Your pin outs worked great. I did notice we had the audio + and Video2+ confused. I fixed the first chart in this post to read correctly.
Thanks to everyone for thier help.
Mike
03-30-2005, 11:29 PM
#20
Great!
Glad that I could help.
Good luck!
Dmitri
01-23-2006, 07:12 PM
#21
I've just fixed my cable as it was showed at the first post here, but it did'nt work, i got 2 red wires that did'nt go anywhere, one went to the 4pin on the usb, and the other one was on the other cable, that one i did'nt find out where went, what can i have done wrong? i've checked the connections 2 times, and it's all connected as they should
01-24-2006, 09:12 AM
#22
hm....just think i found out what my problem was, i don't have the DIN9 contact, i have the one with 10 pins that you screw on...
01-24-2006, 11:46 AM
#24
i've done like the plan tells, but it dont work, but as i said, my connector got 10 pins, not 9 as the DIN9 connector
01-28-2006, 06:41 AM
#25
hmm....i have a DIN9, my bad
but it didn't work, i had all the connections where it should be after the scematics AND after a original cable (i testet it)
what can i have done wrong?? i welded all the earth connections together ofcourse
01-28-2006, 11:57 AM
#26
look at my previous post (on prev. page):
Quote:
Notice - THERE IS NO shield connection between USB, VGA and monitor 14 din connectos. I don't know why, but there isn't.
I don't know if it helps. My oppinion - there should be one COMMON ground, but that's not how original cable is.
Also, the very first pinout in this topic had an error. I don't know if it's fixed.
http://www.astaltsev.com/CarPC/liliput_cable.htm
has correct pinout (at least it helped FireAnt).
Make sure you don't have short circuit where it shouldn't be.
Good luck.
01-29-2006, 05:46 PM
#27
it works  i just had to separate som of the ground points, i didn't read that post that well ;-)
06-23-2006, 06:19 PM
#28
No one answered where to buy a replacement, IS there a place?
06-20-2007, 07:08 PM
#30
Urgent!!! Lilliput GL701 - VGA Wire Connection!!!
Searching here in the forum enough but also in a lot of other sites unfortunately I did not find any answer for how these three wires should be supposed connects???
The first three (*Red =1 / *Green=2 / *Blue=3) I believe that they are connected right…
But the *Black - *Brown - *Yellow, I have not occupied where they should go;?;?;?
Virtuousness & Daring...!
| Thread Tools |
| Display Modes |
Linear Mode
