Old 03-28-2005, 10:30 AM   #1
pugstyle's Avatar
Question Bad tview T-700TS
I got a screen from digitalww.com for about a half year ago and now im going 2 use it but the touch won't work its about 5 cm from the mouse should be can i try 2 calibrate but it won't change it what is wrong whit it ???
Carputer Status Not installed
Car : Peugeot 306 style
Screen : Lilliput 7" touchscreen
Case: homemade plexi
Motherboard: VIA Epia M10000
Power Supply: Mastero MK-4 (still waiting for some parts)
Radio: not sure yet
Software: XP, MediaCar
pugstyle is offline   Reply With Quote
Advertisement Sponsored links
Old 04-21-2005, 11:33 PM   #2
im haveing a similar problem with mine. it has been working just fine for a few months and then all of a sudden i started having calibration issues. now sometimes the touch doesnt work at all. Im going to try to reinstall the drivers and hope for the best, but i suspect the touch panel is bad. its getting very frustrating though, and just in time for meet next weekend too!
System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
Progress: Installation: 90% Dash fabrication: 80%
Parts Needed: USB GPS
meyer64 is offline   Reply With Quote
Old 04-22-2005, 12:44 AM   #3
well i just finished reinstalling all the software and drivers for my touchscreen. I found out something somewhat interesting along the way. Upon installation, my problem remained almost the same. The calibration was still way off, but at least it worked consistantly. I went into the 4 point calibration and it made it more acurate, but still not as good as i would like, so i tried the 25 point calibration, when i was done i got an error " EEPROM access failed!" which leads me to beliave that the 25 point calibration information as actually stored on the touch controller itself! ( i could be wrong, but its a reasonable assumption). i tried again and it worked. now my alingment was almost perfect, so i didnt mess with it anymore. So it seems to be fixed for now, I'll report back if anything changes.
So now the question is what causes this problem? the touchpanel, the controller, or the driver/ config utility? or the combination of them?
Is there another utility that may be better then the touch Kit software?
Old 04-24-2005, 10:10 PM   #4
Problem returned after about an hour of use. I have to continuously realign it. i'm pretty ****ed. i dont know what the problem is, but i think its the touch pannel. does anyone know if i could get one of the 7" pannels from digitalWW and use it wih the existing controller?
Old 08-19-2005, 04:27 PM   #5
Dear Meyer64:
I have the same problem with my tview. Did you find a solution?
Robin Hou
robinfly is offline   Reply With Quote
Old 08-19-2005, 06:08 PM   #6
Jahntassa's Avatar
Thankfully the touchscreen controller is completely seperate from everything else..it shouldn't be too hard to just replace that one part..
Jahntassa is offline   Reply With Quote
Bad Battery or Bad Connection or Altenator? sniz55 General MP3Car Discussion 11 01-30-2005 06:40 PM
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 12:49 PM
*one* bad pci slot? also, bad NIC? InFix General Hardware Discussion 7 11-28-2002 12:49 AM
7" REDANT SCREENS (bad pixel) CHEAP dscustoms Classified Archive 20 06-26-2002 11:04 AM
