Old 03-29-2005, 12:33 PM   #1
SFiorito's Avatar
Question for those that put together their Lilly motorized enclosure
I got my motorized enclosure yesterday, but I'm lost on how exactly to connect the extra yellow cable that comes with the enclosure. Armen's instructions show a cable with four wires, while mine has 5 (1 red, 4 yellow). I already soldered the connections onto the Lilly controller, but I just need to know which pin goes to which wire on the controller. Since it's not at all clear from the pictures. I emailed Armen already, but I just wanted to check on here just in case he can't get back to me today.
SFiorito is offline   Reply With Quote
Old 03-29-2005, 03:46 PM   #2
Raw Wave
Defiler's Avatar
Got mine yesterday as well. When I get to that part try to help if this question has not been answered yet.
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!!
Defiler is offline   Reply With Quote
Old 03-29-2005, 04:56 PM   #3
Did you guys buy the motirized in dash unit? Or which one did you if its not that.
argetim is offline   Reply With Quote
Old 03-29-2005, 06:24 PM   #4
SFiorito's Avatar
the motorized in-dash enclosure for the lilliput's.
Old 03-29-2005, 11:08 PM   #5
Raw Wave
Defiler's Avatar
Ok figured out what to do.
In this picture you see the 5 wires (1 red and 4 yellow)
http://www.digitalww.com/Lilliput_To...h/DSCF4827.JPG
In this picture you see only 4 yellow wires.
http://www.digitalww.com/Lilliput_To...h/DSCF4828.JPG
I am assuming you don't need the red and you can cut it off. Armen please correct me if I am wrong.
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 03-29-2005, 11:15 PM   #6
SFiorito's Avatar
yeah, but which yellow wire goes to what wire on the controller board? well, it won't matter for me anyway because something happened to my controller board. i must have screwed something up because when I put it back together the screen came on for a second then died. I don't even get a signal to the buttons which tells me my controller board died. Everything was working last night (except the screen obviously since I didn't have the controller cable hooked up). i'll have to see if Armen is selling any spare controllers now... to anyone planning to get this enclosure: I recommend letting Armen do it since he's done it a number of times already.
Old 03-30-2005, 12:09 AM   #7
digitalww's Avatar
Using the inverter is not really necessary. What I started doing is just extending the backlight wires by 250mm. This makes the install much easier. I don't have any pictures at the moment but it is easy to do. Make sure that the wire is similar to original backlight wires are.
Armen
digitalww is offline   Reply With Quote
Old 03-30-2005, 12:27 AM   #8
SFiorito's Avatar
yeah, that's what I was wondering?? why they have an inverter in there if the cable just needs to be extended. so now, my question is.... how can I be sure what the problem is with my screen? if the buttons don't receive any power (checked the ribbon cable with a volt meter and nothing is coming through) is it safe to assume the controller is gone?
Old 03-30-2005, 12:43 AM   #9
Raw Wave
Defiler's Avatar
I have a question for you guys...
Is the cable from your original Lilliput as long as the one in this picture?
http://www.digitalww.com/Lilliput_To...h/DSCF4879.JPG
Mine is nowhere near that long and it doesn't reach to the opening of the back of the case.
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 03-30-2005, 12:48 AM   #10
digitalww's Avatar
This is your best bet. This happens very often so you might still be fine. Also check the fuse to see if it is still ok.
Quote: Originally Posted by joshthepilot
The ribbon between the controller and the buttons is a little small for the buttons side. You have to slide it over to one side. Also, if you put it in upside down (pins on other side) it will not work. You can do this while power is plugged into the controller and slide it around till you see the red standby light. Becareful not to reverse the direction of the button board then what the original case held.
Old 03-30-2005, 12:50 AM   #11
digitalww's Avatar
The cable pictured comes with new lilliputs. Some of the old ones might be a little shorter. However I think all cables should be able to reach the back of the housing. I can send you a new one along with your T Panel.
Armen
Old 03-30-2005, 12:54 AM   #12
Raw Wave
Defiler's Avatar
Armen
That would be great. Could you please add more pictures too? I see a red wire that got soldered on one of the cards and I don't know which spot it got soldered to. I thought there was going to be little to no soldering and there is a lot more than I was lead to believe. I suck at soldering and I know I'm gonna be up ****s creek and in more debt before this is screen is done.
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 03-30-2005, 01:00 AM   #13
digitalww's Avatar
If you are just extending the backlight cable then there is very little soldering. I am sure you can do it. I will try to start on the guide ASAP because a lot of you are starting to receive the hosings.
I will send you the cable tomorrow.
Armen
Old 03-30-2005, 01:07 AM   #14
Raw Wave
Defiler's Avatar
Along with the TS?
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 03-30-2005, 01:09 AM   #15
SFiorito's Avatar
no, it's not the ribbon cable. i've fought with it before... and checking the connector with a volt meter there's no signal going through at all. looks like it's the fuse (right next to the DC plug, right? 1A KOAC??). 12V going in, nothing coming out... what are my options? where can I find a replacement for this fuse? I did a preliminary search and didn't find much. Not really sure what to look for either besides a 1A fuse. Is KOAC the manufacturer? Thanks.
Need help! Motorized in-dash LCD enclosure semester project. RPI Geek Fabrication 29 12-14-2006 10:19 AM
Question about this enclosure churnopol General Hardware Discussion 4 03-20-2004 10:17 AM
