Old 04-10-2005, 07:52 AM   #1
mp31023's Avatar
Xenarc LCD in Lilliput
Is it possible to use a Xenarc LCD in Lilliput
mp31023 is offline   Reply With Quote
Old 04-10-2005, 07:56 AM   #2
MySQL Error
Scouse Monkey's Avatar
do you mean with lilliput controller?
Xenarc used a panasonic screen, lilliput a hitachi one. i doubt they are compatible
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-10-2005, 07:58 AM   #3
mp31023's Avatar
No... Just the LCD. Pop the LCD out of the Lilli and put in the Xenarc LCD
Old 04-10-2005, 08:19 AM   #4
MySQL Error
Quote: Originally Posted by joshthepilot
The pinout is the same but the panasonic will not fit easily into the lilliput case.
the hitachi and panasonic screens can be controlled by the same controller then? that is interesting as a linITX controller is cheaper than a Xenarc one and i have a Xenarc screen with broken controller (wont take any vga or rca input but the OSD works)
Old 04-10-2005, 08:38 AM   #5
Raw Wave
Confused's Avatar
You *can* fit a Xenarc LCD within a Lilliput casing (well, the front half at least)
However, the Xenarc LCD has a bigger frame on one side than the other, the Lilliput screen has equal-sized frame. This means to get it central you'll have to remove part of the plastic tabs on the Lilliput casing, and half of the screw holes for holding the LCD in place on one side. You'll also have to remove the tabs that hold the bottom of the screen as the Xenarc panel is also slightly taller.
It *can* be done, but it's a bit of a hack job!
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 04-10-2005, 08:41 AM   #6
MySQL Error
I have swapped lilliput parts with Tview parts sucessfully. I have not swapped lilliput and xenarc but looking at a xenarc right now to make sure, the pinout matches the standard 40 pin rgb pinout. It can be done.
hmmmm very tempting....
josh, do you ahve the pinout data there? would i have to reverse the cable or use an alterntate sided one. (xenarc has conenctors on one side)
Old 04-10-2005, 08:52 AM   #7
MySQL Error
cool,cheers josh. might get a linITX controller and try it. Very strange fault on the controller.
Old 04-10-2005, 09:14 AM   #8
MySQL Error
yeah i cant remember which way up they are but as long as the top LCD is connected to the top controller i shoudl be ok.
FACTS ONLY, Is the Xenarc More Sunlight Readable Than The Lilliput xtreme_db LCD/Display 16 10-24-2004 05:52 PM
4 line LCD used in conjunction with Lilliput mfischler LCD/Display 7 09-18-2004 08:08 PM
FS: 7" Lilliput LCD w/ touchscreen sohr Classified Archive 13 08-25-2004 04:59 PM
Lilliput LCD - Is it really VGA? If so where to buy (US)? ppgt94 LCD/Display 14 06-24-2004 12:12 PM
Controller Board for Lilliput LCD funt4stic LCD/Display 6 05-04-2004 01:47 PM
