DR.
NiN^_^NiN was completely right... i tried the lat two cables in the diagram.. the pink and black and the video rushed to he lcd like white on rice....!!! YESSSS I LOVE U GUYS... thanx for the help....
for those of you with the same problem of this lcd monitor... or a similar monitor... all you have to do is open up your unit...
you will need the following items to create your own cable...
i must warn you.. this process will only give you 1 video imput
1 small phillips screw driver
1 female rca connector ( rca cable can be cut in half for parts)
1 sodering gun with soder (not necessary but better connections)
3 feet of 22 Gauge wire ( the wire with many little wires inside.. not solid )
lets get started now that u have all these.
first take off the screws in the back of your wonderful MOBILE TV M5000 ( or similar model)
now remove the screws holding the board that is on top of the lcd.
leave the lcd connected to the board.. what you need to disconnect at this time is the cable that is comming from the out side to from the plug @ the main board we just uncrewd.
take a look at DIAGRAM 1 to see the lay out..
this is the layout of what you are trying to achieve.
you will only need those 3 wires of the connector...
use 1 1/2 foot 22gauge wire for the +12V wire #4
use the other 1 1/2 foot 22 gauge wire for the -12v wire # 9
now connect the OUTSIDE OF THE RCA to the wire #9
and connect the INSIDE OF THE RCA to wire # 10
try to sorder any of these connections to get the best tranfer of signal..
now use electric tape to safely wrap these babies so they wont short.
UnStoP@ble
<-------- it works
