Old 04-12-2005, 07:41 PM   #1
So, give us new LCD touchscreen options!
Ok, I have finally tweeked my carPC and it is exactly how I want it. It works every time, ALL the time... and for those of you who have built these things know that is a feat
But my stupid Lilliput has that 'ghost image' problem as well as syncing with the display so every 3 out-of 10 times it comes up blank. How frustrating to have the LCD be the problem in your design!!! Plus, don't even get me started on the brightness!
So who has info on when/if a new HIGH BRIGHTNESS 7" touchscreen will be coming out?!?
There has to be something on the horizon, right!?!?
davem is offline   Reply With Quote
Old 04-12-2005, 07:44 PM   #2
MySQL Error
Scouse Monkey's Avatar
i'm looking!!! I found some 300cd/m2 but with that reflective technolgy to make them go brighter in daylight and a 5wire TS (bettert than 4 wire) but they cost £500! ($900) so i doubt you would want to payt hat much!
if anyone has a smached Xenard take the LCD apart and post lots of high res pictures - maybe we can design a new LED backlight system.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-12-2005, 07:49 PM   #3
lastberserker's Avatar
From what owners say around here 7"s have non-standard (for video cards) resolution. So, if a new one comes out, it would be wonderful to have one with more standard resolution
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
lastberserker is offline   Reply With Quote
Old 04-12-2005, 07:51 PM   #4
MySQL Error
jcdillin's Avatar
i'm already working on a upgrading my lilliput brightness
right now i'm just trying more ccfl's but next i'm going to try ultrabright LEDs
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 04-12-2005, 07:53 PM   #5
MySQL Error
PICS PLEASE!
I have an electronics clean room at work i am eyeing up for doing some kind of brightness mod in!
Old 04-12-2005, 07:54 PM   #6
MySQL Error
Quote: Originally Posted by joshthepilot
One bonus to the hitachi screen (lilliput) is that you can seperate it from the backlight module and the only pcb is that little square corner piece. So if you create a brighter backlight, it is very easy to mount. The panasonic screens have a much larger pcb to have to work with and avoid breaking.
Josh, do you have any exploded pics/diagrams of the panasonic and hitachi LCDs you could send me?
Old 04-12-2005, 08:10 PM   #7
MySQL Error
jcdillin's Avatar
I can take some more if you want scouse
this is the lilliput raw panel
and the diffusers I pulled from a bigger LCD
肚子笑痛了
S60 Install
Old 04-12-2005, 08:24 PM   #8
MySQL Error
jcdillin's Avatar
yeah on the hitachi screen, the panel comes off the backlight module
肚子笑痛了
S60 Install
Old 04-12-2005, 08:27 PM   #9
Has anyone tried to use electroluminescant material as a backlight for an LCD? I was on a website the other day that sells it in sheets big enough to do a 10 in screen. I was thinking it might give off more light than just a few LED's.
sansoo24 is offline   Reply With Quote
Old 04-12-2005, 08:28 PM   #10
MySQL Error
jcdillin's Avatar
I have a sheet of it, and it's not bright enough at all
肚子笑痛了
S60 Install
Old 04-12-2005, 10:45 PM   #11
wi77iam's Avatar
I was going to try to build a better backlight using some of these led light bars. You can split them into 3 inch sections (3 leds per section) so I want to arrange them to cover as much of the 7 inch screen as possible. I think I can fit 9 sections for a total of 27 leds. They're pretty bright using 12 volts. Maybe put a dimmer to control brightness. Then I just need some kind of diffuser.
wi77iam is offline   Reply With Quote
Old 04-12-2005, 11:19 PM   #12
ddn
EL panels are not even CLOSE to the brightness you're looking for.
Remember, even with bright LEDs, you need to diffuse it somehow.
My thoughts are more along the lines of using tinted film to reflect sunlight back out before its able to hit the back reflective panels and wash out the display. I think a layer of 2-way mirror tint would be all you need to solve this problem.
What do OEMs do?
ddn is offline   Reply With Quote
Old 04-12-2005, 11:22 PM   #13
My Village Called
0l33l's Avatar
Quote: Originally Posted by ddn
What do OEMs do?
Well, BMW takes the cheap way out and hides the display under a sunvisor
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 04-13-2005, 12:50 AM   #14
linuxguy's Avatar
Quote: Originally Posted by jtp
I would just mount the lcd panel on the end of a 10 Million candle power light.
Ha ha, if only it were possible...
I like the 2 way reflective stuff...i saw some at Home Depot the other day... If i ever get around to driving in the day, i might have to try it...let me know if it work!
I had a perfect quote to go here,
but hell only knows what I did with it....
linuxguy is offline   Reply With Quote
Old 04-13-2005, 01:01 AM   #15
My Village Called
0l33l's Avatar
I know what you're talking about. Like the lights they use in projectors. Well, they're really hot
GammaControl v2.4
SKINbedder v3
Xenarc 7" LCD, but no touchscreen celicagtsblak LCD/Display 5 09-27-2004 11:27 AM
FS: 15inch LCD and touchscreen CURTISBEEF Classified Archive 10 09-25-2004 01:46 PM
cheap lcd + touchscreen options? dunks LCD/Display 2 05-25-2004 10:05 PM
WTB: 7" - 8.4" LCD touchscreen robiewp Classified Archive 2 05-25-2004 09:36 PM
can you give me LCD shop on internet..? helloman General Hardware Discussion 1 02-03-2004 11:44 AM
