the other side of case, you see a big metal thing, that's the LCD module. two pieces of metal bracket one of each side hold it. take off the 4 screws you can have the LCD in hand, Torisan TM080SV-22L03. it's interesting that several websites I've googled out show this LCD as 800x600 with brightness only 150. mp3car listed it as 280, digitalww says 380, neither mention with or without TS. if the LCD is only 150, how could TS increases the brightness
the dimension of this LCD module is
width: 7-3/8"
height: 5-5/8"
thickness: 7/8" with TS. 3/4" without. there are black foam spacers around between TS and the LCD.
