Old 04-14-2005, 11:44 AM   #1
senseless228 is on a distinguished road
Double-Din touch screen LCD?
I have a stock double-din headunit on my '00 xterra, and i wanted to do the whole carputer setup, however all the 7" touch screens i've seen seem wider than double-din, and i prefer a standalone double-din, instead of a single-din motorized one, i want the screen to pretty much just stay there, if worst comes to worst i can cut out the dash a little wider for it to fit, but is there any double-din sized touch screen LCD's i can use?
senseless228 is offline   Reply With Quote
Old 04-14-2005, 03:47 PM   #2
kmcniece's Avatar
kmcniece is on a distinguished road
I believe the 7" screen is smaller than the opening.
The double-din is 7" wide by 4" tall....
The screen is actually less than 7" wide and just less than 4" tall(without the housing).
Check the newbie section for Lilliput and Xenarc Stickies.
Good Luck!
EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
Status:
Installed & Working....
Custom enclosures
Newbie Guide
kmcniece is offline   Reply With Quote
Old 04-14-2005, 04:52 PM   #3
lish is on a distinguished road
Check out this link if you are looking for a good fit in a double-din:
http://www.tmz.com/wrx/bezel.html
Really clean install if you don't want to mod your dash.
The superfluous, a very necessary thing.
lish is offline   Reply With Quote
Old 04-14-2005, 05:57 PM   #4
thats really tight, that may be just what i need, however the measurements of the liliput monitor were more than 7" wide and more than 4" high, i'm referring to the 7" touchscreen LCD by them. thats whats confusing me. i was also looking at the dynamix ultrabrite 7" lcd.
Old 04-14-2005, 06:13 PM   #5
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
The lilliput has a slightly smaller housing than the xenarc. I'm putting my xenarc into a double din hole at the moment, I bought a conversion facia for my car and am going to take a dremmel to it in the morning.. hopefully I'm going to try and fit the xenarc including the buttons.. we shall see
CdR
CdRsKuLL is offline   Reply With Quote
Old 04-14-2005, 09:19 PM   #6
dylantinc is on a distinguished road
I too am looking for a clean install for a double din. Without shredding the console. My idea is to use the headrest shroud of the lcd to mount on the empty double din case. Then, cut the back out of the shroud. Install pins on the sides of the lcd and inner part of the shroud so i can swivel the screen and also lift the screen to access the mac mini that will be so cleverly sitting behind it. If all goes well of course.
dylantinc is offline   Reply With Quote
Old 04-14-2005, 09:50 PM   #7
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
CdR
i thought you already had a xenarc in your car, what car is this for?
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 04-15-2005, 11:36 AM   #8
will he do it with the newer LCD? and i hear the dynamix ultrabright has a high contrast ratio of 400:1 how does the lilliput compare?
Old 04-15-2005, 11:53 AM   #9
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
The M3 cab is going
he has now got a Ford ST220 (mondeo)
Enforcer is offline   Reply With Quote
Old 04-16-2005, 12:07 AM   #10
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
check this out...............
thanatos106 is offline   Reply With Quote
Old 04-16-2005, 10:04 AM   #11
i got an '00, but are you saying that your xenarc fit double-din with the housing?
Old 04-16-2005, 12:33 PM   #12
Para Laura
Don't know about the housing,this is a mod.
Old 04-17-2005, 02:08 AM   #13
is a 200:1 contrast ratio good? I was looking at the dynamix ultrabright, and i realized it had a 400:1 contrast ratio which caught my eye. However i like the fact that the guy made a double-din bezel for the lilliput, if anyone has that 7" lilliput touchsreen, let me know what you think of the quality and contrast ratio of it.
Old 04-18-2005, 01:38 PM   #14
i like that bezel idea to get flush in dash, but some of the issues i'd have with that are a. isn't the lilliputs contrast ratio only 200:1...bad in daylight? and the buttons aren't accessible anymore so i would not be able to switch from my computer display to a...ps2...or camera...or stuff like that. thanks for the input so far.
if there are other similar installs and bezels made for maybe a xenarc or a dynamix or anything like that, please please please let me know, i want a variety of options, thank you for all the input so far.
Old 04-19-2005, 04:11 PM   #15
welcher is on a distinguished road
I'm getting ready to put a xenarc in my 03 xterra. Are you moving the double din to the free space below the the orignal location? Any thing major you have run into yet?? I do not plan on keeping the factory radio.
welcher is offline   Reply With Quote
Double DIN LCD, and other questions (sanity check) Lum Newbie 35 05-11-2005 04:49 PM
Need Double - Din Bracket - Mustang 05 mbkowns LCD/Display 4 04-02-2005 03:05 PM
double DIN LCD screen nadir_s LCD/Display 3 01-03-2004 10:21 PM
adding touch screen kit to indash LCD??? kurtm LCD/Display 5 07-19-2003 02:17 AM
8.4" VGA LCD TFT Touch Screen Kit Zip-Lock Classified Archive 5 12-27-2002 09:38 AM
